(WIP) Rover P6 conversion
Markb
Post by Markb »
I am planning to convert my 1969 Rover P6 2000 automatic with the help of the team at Electrogusto in Sydney. They are doing the mechanical and electronics work so I’m not quite sure whether I qualify to post in open inverter but here goes.
We are considering Lexus transmissions to power the rear wheels through the existing driveshaft and trying to decide between gs450h and gs300h. Apart from the 300 being a single speed unit with less weight and no need for external oil pump they seem very similar but there doesn’t seem to be much published experience with completed projects using the 300. GS450H is the front runner as it seems like the tried and true option but the car is quite small for a 4 door sedan so the gs300h would fit a lot better in the transmission tunnel. The weight saving would also be a bonus. At this stage can anyone tell me whether a 4 door sedan like this will cruise at 100kmh using a gs300h? Does the process of connecting the gs300h to an inverter differ in a major way to connecting a gs450h? Any other thoughts or suggestions?
Other info: Diff ratio 1.54, tyre diameter 615mm, current weight 1300kg. Aiming for 150km range including highway driving at 100kmh. Drag coefficient unknown (but not low). I made a scan of the engine bay and transmission tunnel.
(Note: for some reason opening it in blender gives millimeters as metres. Also the tunnel cross sectional measurements are a bit overestimated because it’s scanned from inside the car as the original transmission is still in place).
ianlighting
Has thanked: 258 times
Been thanked: 189 times
Re: Rover P6 conversion
Post by ianlighting »
Can’t comment on your Lexus donor, but regarding range I would have thought that will mostly depend on battery weight. Which = kWh. What are your plans?
Be nice to see an image of your car.
Has thanked: 330 times
Been thanked: 848 times
Andy has his Z3 driving with the GS300h, its got plenty power.
viewtopic.php?t=4064
Are you sure your diff is a 1:1.54 ratio? The info I find with a quick google yield 1:3.54 ratios.
Markb
Post by Markb »
Picture of car attached. I typed the diff ratio incorrectly. It is 1:3.54. I want to get at least 150 km on it. Batteries will be 16 CALB Modules for a total of 35kWh. Sounds like power wont be an issue but I havent seen any posts about top speed with the GS300. I’m aiming for highway driving at 100kmh. Occasional 110-120kmh would be nice.
Re: (WIP) Rover P6 conversion
So the IS300h has a 4600 rpm prop output speed, so you should be able to do the math from there.
Markb
Post by Markb »
Thanks tom91. That gives me 94mph which is plenty.
marcexec
Has thanked: 1043 times
Been thanked: 111 times
Post by marcexec »
Hi Mark, is there any progress on this - physical or mental? :)
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
Markb
Post by Markb »
Progress report:
Back from the painter last week. GS450h installed along with modified drive shaft.
