Gs450h Project beginning stages
RianGill
Post by RianGill »
Hi all,
I have just recently began a project using the Gs450h inverter and drivetrain to hopefully complete a full conversion of a 1997 Jag Xk8 as my 6 month work placement in University. I am at the stage where I have now just received the inverter, transmission, oil pump & controller and entire loom. Luckily we have the Gs450h so we are able to take looms and components were needed.
I have done quite a lot of research over various videos, threads and wiki pages in the last few weeks. I am using the Zombieverter VCU board and have watched countless videos from Damien to get comfortable. I am about ready to start my first spin tests but the one thing I was hoping to confirm is do I need the ISA Shunt for the first stages of bench testing? This is the only component I do not have currently and upon reading through the wiki support page I did notice a line: "Without a proper UDC measurement, the ZombieVerter will fail precharge and never go into run mode."
If I am using two supplies, one +12V and the other around 30~40V for just initial stages to ensure operation and wiring will I still need the Shunt or an equivalent way or providing a UDC value to the VCU.
Would be great to hear from someone with a bit more experience on the topic. :)
Has thanked: 204 times
Been thanked: 556 times
Re: Gs450h Project beginning stages
RianGill wrote: Wed Mar 26, 2025 11:29 am ISA Shunt for the first stages of bench testing?
Yes.
RianGill
Post by RianGill »
And does that just have to be measured across the high voltage + and -. For these initial test at around 30V will a fully functioning precharging setup be needed? I know on the older Gs450h VCU that wasn't the case but with the Zombieverter is that needed or only a UDC value for it to read.
The Shunt needs to measure it.
You can always manually precharge with a resistor. Zombie wont know it has not done the precharge itself, it will skip through it if the voltages UDC and UDC2 are matching.
I do not know at what voltage the Lexus inverter will work.
RianGill
Post by RianGill »
I have gotten the ISA Shunt since then, (although I didn't realize it doesn't come with connecters - lesson learned), and will be ready to go very soon.
One question - one the Lexus Gs450h transmission the gear selector solenoid, do you also wire this to your +12V switch which indicates to the zombie the direction, pins 54 and 53.
Currently I just have the switches sending 12V to those pins without the transmission side of the wires being connected, seems like a simple answer of yes of course because how would the transmission know, but still wanted to check
RianGill wrote: Wed Apr 09, 2025 2:17 pm one the Lexus Gs450h transmission the gear selector solenoid
What are you on about? There is a gear selector switch on the GS40h. https://openinverter.org/wiki/Lexus_GS450h_Drivetrain
Check the wiki on how to wire the selector and gear solenoids and pressure switches used in the GS450h
robertwa
Has thanked: 112 times
Been thanked: 126 times
Post by robertwa »
It's just a selector switch on the transmission - if you want to use the shifter mechanism as originally designed, then wire it in. If going with something different, such as F-N-R switch on dash etc, then no need. You may still want a mechanical linkage to engage and disengage the parking pawl.
As Tom mentions, the gear solenoids and pressure switches are different, and used for things like high/low. Wire those as per wiki
RianGill
Post by RianGill »
I understand that is a normal selector, I am looking right at it lol. Just questioning the integration of the solenoid wiring with the zombie wiring, not how a gear selector works.
Unsure yet of how I would like to integrate into the dash and do unique parts with it but i'm sure it will come up soon.
RianGill wrote: Wed Apr 09, 2025 3:09 pm Just questioning the integration of the solenoid wiring with the zombie wiring
Just to be clear you are on about the Gear Shifter, unlock solenoid?
this is something I have been working on implementing. There is this functionality in the testing branch now.
RianGill
Post by RianGill »
I think I actually just confused myself upon further reading. So yes I am interested in doing some more unique setups going forward but I just now want a basic operational unit.
Instead of all the complicated stuff I was mentioning with the switches I have now realised and am guessing that you just wire "D" to pin 54 and "R" to pin 53, when one of those gears in selected that will send the signal to that pin indicating to the VCU which direction it is going, instead of not having to deal with the nonsense of multiple selectors that I was suggesting.
Does the Shifter plug send a 12V signal? or will a pull up/down resistor be needed in order to correct the signal to the VCU?
Follow the wiring info on the wiki. https://openinverter.org/wiki/Lexus_GS450h_Drivetrain
12V into the transmission mounted shifter position sensor/switch
RianGill
Post by RianGill »
tom91 wrote: Thu Mar 27, 2025 5:14 pm The Shunt needs to measure it.
Hi again,
Back now finally with ISA connectors, have it wired up (very basic first test) using just a headlight bulb to test communication with shunt and zombieverter. When bench testing (using power supplies), what must be done in order to get by the pre charge fail error with the zombie verter.
Also a few basic questions, I just want to make sure my basic understanding is correct, when using the GS450h system with a zombieverter VCU, am I correct in not having to open the buck/booster converter? currently I have completed all the wiring from the transmission, shunt, vcu, etc, but I have not opened anything with the inverter except for access to the two terminal posts on the side which is where I am putting my HV source.
Currently the VCU has communication, getting information from the shunt (however it is all random unreadable values, i believe it might be due to the wiring on the shunt, only using crocodile clips for first com test), throttle fully working and direction working. I want to get a reasonably low voltage test working before I up the supply. Currently when applying power to the inverter I still hear no inverter wine, I think I might not be applying the min voltage/current needed, I have tried 30V @ 6amp or 61V @ 4amp, and still no noise from the inverter.
So in summary:
1. How does pre charge fully work for bench testing?
2. When using zombie verter is it really just plug and play or is there additional steps I have been naive too?
3. Min voltage/current needed for inverter testing?
Thank you.
Have a look here it will work the same as here.
viewtopic.php?t=6370
RianGill
Post by RianGill »
Yup was the exact same problem with the startup when initializing the shunt.
That is all working now, just need a precharge resistor now and then test run the full setup, not sure if the 30V @5amp will be enough to get the inverter operational.
Thank you again
RianGill wrote: Thu May 22, 2025 8:27 am30V @5am
No.
Get atleast 60V worth of battery. The user in the linked topic had issues with his 60V 5A supply not providing peak power requirements and sagging too hard.
