Lin heater logs from e2008
GeneralScanner
Has thanked: 12 times
Been thanked: 10 times
Post by GeneralScanner »
I have some Lin logs from my missus's e2008
From the heater and I believe a/c Lin bus this runs a 5kw eberspacher heater.
I started the log full hot I believe then full cold then full hot again. I did verify the heater hose were getting warm.
https://github.com/Gn1c3/Lin-E2008-Heater-a-c/tree/main
Has thanked: 204 times
Been thanked: 556 times
Re: Lin heater logs from e2008
One of these?
GeneralScanner
Yep
Landsi
Post by Landsi »
Cool! You wouldn’t happen to have come accross a pinout of these, would you? I have tried and failed to find one in the past…
Plan to build someday soon<TM>:
VW T3 Bus
Leaf Motor Stack incl Transaxle
Brat Industries VW Driveshaft Adapters
Model 3 55kwh Battery / MEB 58kwh Battery
Foccci CCS
Zombieverter VCU
GeneralScanner
GeneralScanner
4F0973703
Also available as a pigtail for those who don't trust their own crimping ability
Landsi
Post by Landsi »
Brilliant! Very thanks, much clap 👏!
VW T3 Bus
Foccci CCS
Zombieverter VCU
Can you post raw salae log on github so it can be exported in a different format
GeneralScanner
I got one on the way to play along :)
GeneralScanner wrote: Sat May 17, 2025 1:36 pm Done
Decoded https://github.com/Gn1c3/Lin-E2008-Heater-a-c/pull/1
GeneralScanner
Heater is 80f5
What is the other component on the same network? AC compressor or a pump?
GeneralScanner
8020 is the a/c compressor
GeneralScanner
1775 is the "electric drive train supervisor ECU".
Can you please get some logs of it running steady just heating.
Then a log of going from HVAC on to off.
Small issue to gum up the works, it has a heatpump setup so using the AC compressor to heat the cabin. We will need to figure out how to force it to do ptc heating.
https://ev-database.org/uk/car/1947/Peu ... 008-54-kWh
Heat pump (HP)	Yes
HP Standard Equipment	Yes
GeneralScanner
There wasn't a pid in diagnostic data for heater.
There wasn't a diagnostic activation for the heater.
How about if I unplug the compressor.
Was that 'heat pump yes' from my data?
GeneralScanner
Could try charging.......it's a battery heater in principle..... although heater hoses come right off it
GeneralScanner
Yeah if I unplug the compressor and the coolant still gets hot then it has to be the heater.
GeneralScanner wrote: Tue May 20, 2025 4:03 pm Yeah if I unplug the compressor and the coolant still gets hot then it has to be the heater.
That is the quickest test. Also good to easily identify the LIN ids for the AC compressor
The yes heat pump is from reading up on the e-2008 specs
Got it working it tries drawing current and pulls down my HV power supply. Now its time to do testing on a real setup (I do not have one).
Lin bus info below
https://github.com/Tom-evnut/Lin-E2008-Heater-a-c
AMP3R
Been thanked: 51 times
Post by AMP3R »
GeneralScanner wrote: Fri May 16, 2025 3:31 pm I have some Lin logs from my missus's e2008
Hey, can you make logs from lin of steering wheel? I want to turn on the lights in buttons.
GeneralScanner
My HV wiring just rocked up.
Part number 4-2103177-1 for the housing.
A TE HVA 280 apparently.
Stellantis part number is 9826145080 and has two of these connectors on either end of a pair of cables. The hvil appears to be internal to the plug (can't see any external LV wiring) .
Back of plug to back of plug is 30cm
It also is a nice and readily available connector which is a bonus.
https://www.te.com/en/product-4-2103177-1.html
Note this is just the housing not a full set with crimps, backshell and seals.
