Hi all,
I'm after some HV fuses, Littelfuse HEV or similar. Bolted tab style. 54mm hole pitch.
I'm after 1x20A, 1x 30A, and 1x 50A unit.
I've only been able to find these new for approx £20 each, there are plenty of cheaper alternatives, but they are all in the US with high shipping rates.
Does anyone have anything available?
Cheers
Wanted: HV fuses
- clanger9
Re: Wanted: HV fuses
What voltage - and do they have to be that pitch? The smaller BS88 fuses are usually only good to 240V DC (check the data sheet).
The longer "690V AC" BS88 fuses are cheap and usually good to 500 VDC:
https://docs.rs-online.com/e268/0900766b814049f5.pdf
- jnsaff
- Has thanked: 3 times
- Been thanked: 8 times
Take a look at Solar PV fuses. They are usually up to 1000V DC and these current ratings should be fairly common.
xp677
- Been thanked: 15 times
Ah sorry, forgot to add, the system is 320V DC.clanger9 wrote: ↑Thu Apr 02, 2020 4:29 pm What voltage - and do they have to be that pitch? The smaller BS88 fuses are usually only good to 240V DC (check the data sheet).
I didn't think about looking at the DC ratings of AC fuses, good idea.
I've already built the enclosure based around that pitch as it seems to be the most common for this type of fuse.
- clanger9
What type of fuse is it? 54mm pitch doesn't seem to be a BS88 size.
This is a great resource: https://docs-apac.rs-online.com/webdocs ... 59a786.pdf
xp677
I based it on the Littelfuse HEV range:
https://www.littelfuse.com/~/media/auto ... asheet.pdf
The "bolt down (ISO)" package.
Because I already have a bunch of HEV fuses, so basing my project on them makes sense. Yes I am aware they don't come in a 50A rating.
I thought these were a common size for EV fuses?
- clanger9
Ah, I see. Yes, "HEV" fuses are around £20 each as far as I know...
Have you tried Altway? They sell Adler fuses.
http://altway.co.uk/wp-content/uploads/Adler-PDF.pdf
xp677
I haven't tried them. I doubt they will sell single fuses, especially since you have to fill out an order form on their site.
My hope was that someone on this forum would have some so sell, second hand, leftover from other projects. If not, that's fine, I'll buy them.
