Unlocking the power/torque of Prius gen 3 drive train?
Has thanked: 328 times
Been thanked: 847 times
Re: Unlocking the power/torque of Prius gen 3 drive train?
Please provide the param file for V2.3
What gearstick are you using?
Landsi
Has thanked: 15 times
Been thanked: 7 times
Post by Landsi »
Did you re-select and save your inverter?
https://github.com/damienmaguire/Stm32- ... /tag/2.22a
Plan to build someday soon<TM>:
VW T3 Bus
Leaf Motor Stack incl Transaxle
Brat Industries VW Driveshaft Adapters
Model 3 55kwh Battery / MEB 58kwh Battery
Foccci CCS
Zombieverter VCU
Ghia66
Has thanked: 750 times
Been thanked: 65 times
Post by Ghia66 »
tom91 wrote: Mon Dec 29, 2025 4:58 pm Please provide the param file for V2.3
Will do
Simple 3 way switch
Ghia66
Post by Ghia66 »
Landsi wrote: Mon Dec 29, 2025 6:00 pm Did you re-select and save your inverter?
I didn’t re select the Prius as it came across when I updated the parameters from my saved 2.15A parameters.
The only thing that I could tell that didn’t come over was the BMW S box.
Post your v2.30A param download.
Ghia66
Post by Ghia66 »
tom91 wrote: Tue Dec 30, 2025 9:41 am Post your v2.30A param download.
params.json
(2.14 KiB) Downloaded 6 times
Couldn’t find MG1 or MG2 available for selection
Ghia66
Post by Ghia66 »
tom91 wrote: Mon Dec 29, 2025 3:46 pm So even after a 12V power cycle it does not work.
Can you please try a release that is older? like V2.22A or 2.20A It is possible a change I made for the testing Greg was doing in his VW Rabbit causes issues for your setup.
I installed 2.20A and sadly it still doesn't move.
Attached is the log and 2.20A parameters
log (1).csv
(1.66 KiB) Downloaded 4 times
params (1).json
(2.15 KiB) Downloaded 4 times
[attachment=1]
If you flash it back to V2.15A you get drive again? Surprised it just refuses to work.
Your V2.20a log does not show Potnom or Torque, this stop it from driving.
Will need to work out what is different if it works on V2.15A makes it work again.
Ghia66
Post by Ghia66 »
Thanks Tom, I will go to 2.15A and see what happens
Ghia66
Post by Ghia66 »
tom91 wrote: Tue Dec 30, 2025 1:04 pm If you flash it back to V2.15A you get drive again? Surprised it just refuses to work.
Sorry Tom, how do I flash it back to 2.15A?
I tried “updating” it to 2.15A and it remained on 2.20A
Ghia66
Post by Ghia66 »
Thanks so much.
This file then 😊
Ghia66
Post by Ghia66 »
tom91 wrote: Wed Dec 31, 2025 10:14 am Yes update it to the https://github.com/damienmaguire/Stm32- ... /tag/2.15A
Okay, so I downloaded the 2.15A bin file as linked and upgraded the Zombie.
Unfortunately the file seems to be 2.20A on spot values even after numerous Zombie reboots and refreshes… is it possible to be the wrong file? 🤞
Ghia66
Post by Ghia66 »
So back to 2.15A with the help of Hakan and his soldering/ ST link magic. The car is back up and running after loading up the previous parameters.
Keen to try whatever is required to progress the Prius 3 experience
There must be something on your setup causing problems. Damien utilizes a Gen 3 Prius on the bench for zombie release testing.
Not the best to just go at it if it means risking not being able to move the car though.
Ghia66
Post by Ghia66 »
Thanks Tom and Damien.
I really would like to try 2.20A again and see if we can get the car rolling with all the great features.
I rewatched Damien’s video on 2.20A and also Greg’s latest one and think that maybe I could have the wrong dirmode setting 🤞
The Ghia isn’t a daily just an exciting rolling experiment so I am going for a 2.15A drive with logs and then upgrade to 2.20A 🙂
Ghia66
Post by Ghia66 »
log (1).csv
(5.39 KiB) Downloaded 5 times
Well just back from an enjoyable drive.
The car is such fun!
Ghia66
Post by Ghia66 »
Well 2.20A software is loaded and I have uploaded my 2.15A parameters.
Changed;
Transmission to manual
Shunt type to Sbox
Dir mode to switch
Looks promising but car is not moving!
params 2.json
(2.14 KiB) Downloaded 3 times
log (1) 2.csv
(3.91 KiB) Downloaded 5 times
I am sure that there is something obvious that I am missing!
Change inverter and change it back again. Can you also please post your inverter serial number/part number
Ghia66
Post by Ghia66 »
Thanks Tom, will do tomorrow
Ghia66
Post by Ghia66 »
tom91 wrote: Tue Jan 06, 2026 6:13 pm Change inverter and change it back again. Can you also please post your inverter serial number/part number
Changed the inverter from Prius 3 to none and back to Prius 3 and powered down/up the Zombie, unfortunately the car didn’t move.
Did you provide an over view of your wiring? Just want to check its all been done right. Mainly interested in the grounds and 12V supplies and relays.
Ghia66
Post by Ghia66 »
tom91 wrote: Wed Jan 07, 2026 4:35 pm Did you provide an over view of your wiring? Just want to check its all been done right. Mainly interested in the grounds and 12V supplies and relays.
I don’t have a wiring diagram but I will take some detailed photos tomorrow to show the setup.
I slavishly followed Greg’s Rabbit wiring etc and because of having worked on quite a lot of VWs and Subarus I made sure that there is an abundance of grounds.
Ghia66
Post by Ghia66 »
12volt wiring layout and grounds
Is all the 12V to the inverter via that relay?
If the issues remains like it does need to confirm what inverter Greg has in his rabbit and what firmware was used as a base for testing on it (yes I did write it but its a while ago).
