VW A/C Compressor
Forum on Volkswagen related hardware, so VW, Audi, Seat, Skoda etc.
muehlpower
Been thanked: 186 times
Re: VW A/C Compressor
Post by muehlpower »
7yatna wrote: Tue Jul 04, 2023 8:56 am i did the same thing but it looks like the control message format for my compressor is a little bit diffrent so no change in the feedback message.
i will take another try at it or i will go tesla can controlled compressor.
thank you for your help on the heater it worked as you mentioned.
Have you tried to send all IDs filled with data and with different lengths with the right checksum?
m.art.y
Has thanked: 38 times
Post by m.art.y »
muehlpower wrote: Wed Jul 05, 2023 9:18 am Have you tried to send all IDs filled with data and with different lengths with the right checksum?
I'm not sure what the pinout is yet 😊 Ideally would be looking to include this heater into the Zombie to expand the range of heaters available.
m.art.y
Post by m.art.y »
What is the power output of the DBK heaters by the way? Does not say on the label.
alexbeatle
Has thanked: 82 times
Been thanked: 35 times
Post by alexbeatle »
muehlpower wrote: Sun Apr 18, 2021 8:06 pm I found the LIN messages for the water heater. The feedback comes on ID48. Byte 0 is power. 13 for 770W, 26 for 1540W. ID28 is sent for control. Byte 0 is power, last bit of byte 1 starts and stops.
connectors are:
HVA 280 KEY_E from TE +HV near to the body, -HV far from the body
1J0973714 1= +12V , 2= GND, 4= LIN
Sorry a little of topic, but are you aware of any limitations on how this heater can be mounted? I'm looking to mount it horizontally flat.
I so far only found good illustration of these used in audi e-tron and they're mounted like this....
As an example. Tesla battery heater has mounting orientation limitation as well described by Lars here: https://www.evcreate.com/using-tesla-th ... y%20heater
modellfan
Has thanked: 20 times
Been thanked: 61 times
Post by modellfan »
I am wondering the same. Which one is coolant input ? WHich one is coolant output? Which orientiation does it have in the car?
golfdubcrazy
Been thanked: 11 times
Post by golfdubcrazy »
modellfan wrote: Sat Mar 30, 2024 4:59 pm I am wondering the same. Which one is coolant input ? WHich one is coolant output? Which orientiation does it have in the car?
Hi, if this is for the HV heater i posted the answer on the correct post below
viewtopic.php?p=69292#p69292
hope that helps :)
BRalf
Post by BRalf »
Hello,
I've been trying to establish LIN communication with 12E820803E for several days now, without success.
I see that many people have succeeded.
I showed how I do it in the photos, but I must have missed something. Does anyone know why I'm not getting a response from the compressor?
thank you in advance for your help.
manny
Has thanked: 58 times
Been thanked: 159 times
Post by manny »
If I see it correctly you have GND connected to pin 6 and not pin 5 as per the wiki.
https://openinverter.org/wiki/VW_A/C_Co ... ite_note-4
8= +12V , 5= GND, 2= LIN
  • PSA battery (50kWh)
  • Zombie VCU
BRalf
Post by BRalf »
Thank you manny.
Now i have reply from compressor, but from id 0x21.
response follows request for response.
I can't construct a frame to make the compressor respond manually, maybe it needs to be woken up earlier.
I see that my compressor is not a typical model.
Has anyone had experience with this version?
BRalf
Post by BRalf »
Good morning,
The compressor is already running (I had to enable MONITOR mode in the program).
However, I'm not getting a response from the compressor.
The compressor stops after about 3 seconds. (I have the input port plugged and the output port open, but the compressor doesn't seem to know this).
What could be wrong?
