Simp BMS
alexbeatle
Has thanked: 84 times
Been thanked: 36 times
Re: Simp BMS
Post by alexbeatle »
As I continue my fast charging tests, would you say it is expected for the most positive module to be the hottest?
All in series. 1 most negative, 14 most positive.
After charging from 53% to 73%, starting at 125A, but gradually reduced to 85A by the BMS.
Has thanked: 386 times
Been thanked: 991 times
Re: Simp BMS
alexbeatle wrote: ↑Mon Nov 04, 2024 5:26 am As I continue my fast charging tests, would you say it is expected for the most positive module to be the hottest?
There is some thing strange going on, on your final module the delta across the module is the largest. Is the cable used there properly fastened?
Due to the way the ribbons run and where the temp sensors are, the temperatures are quite effected by the HV connection to the modules busbars.
alexbeatle
Re: Simp BMS
tom91 wrote: ↑Mon Nov 04, 2024 2:30 pm There is some thing strange going on, on your final module the delta across the module is the largest. Is the cable used there properly fastened?
Thank you. I'd say the connection looks good. That was my first check.
As part of this fast charging test I was aiming for 80% SOC, so this is the first time I've reached balancing levels >3.9V/cell with higher charging current.
So balancing was activated as seen on the snapshot. 14 Tesla 5.3kWh modules (74p6s) = 84 series strings, also seen on the snapshot - so all discovered. Unfortunately, I lost the logs this time, but I do recall my dashboard display reading cellbal.val=82 from bms.
Does that mean we're balancing all but last 2 strings of cells, which incidentally fall into the last module?
I assume, Tesla modules passively balance, by wasting the charging/discharging current via balance resistors (heat) on the cells that need no balancing.
marucha79
Been thanked: 9 times
Re: Simp BMS
Post by marucha79 »
Hello. Did someone rewrite SimpBMS code for teensy 4.0 successfully and will share it? The hardware issues are less problematic then code for me.
Re: Simp BMS
marucha79 wrote: ↑Sun Dec 15, 2024 1:08 pm SimpBMS code for teensy 4.0
Not that I am aware of, it should be pretty straight forward to do.
mane2
Has thanked: 51 times
Been thanked: 67 times
Re: Simp BMS
Post by mane2 »
marucha79 wrote: ↑Sun Dec 15, 2024 1:08 pm Did someone rewrite SimpBMS code for teensy 4.0 successfully and will share it?
I have done Teensy 4.1 version of SimpBMS. It's the BMW & Outlander version which is fork of Tom's BMW variant but I think same modifications work on any version. It just have my custom stuff in it, e-paper display etc code. Haven't tested anything else than CAN1 and working with BMW batteries. Which SimpBMS variant are you after? I could clean it up and share if you want to modify your version by yourself.
marucha79
Re: Simp BMS
Post by marucha79 »
It would be great. It has to work with Outlander battery and charger. I want copy @AOT93 solution described in this topic: viewtopic.php?t=2167 . Here is customized SimpBMS code: https://github.com/aot93/OutlanderPHEVB ... anderBMSV2
mane2
Re: Simp BMS
Post by mane2 »
Here's a link to quickly converted Teensy 4.1 version of SimpBMS BMWPhevBMS https://github.com/amattila/BMWPhevBMS-Teensy41
Tested that it runs on Teensy 4.1 and with my other custom version I have tested that canbus works. Use at your own risk, as always :)
Open the project folder with VS Code + PlatformIO.
marucha79
Re: Simp BMS
Post by marucha79 »
Thank you. It will save a lot of my time and makes easier PCB projecting, as I was not sure about pin assignment.
mane2
Re: Simp BMS
Post by mane2 »
I didn’t change any pin numbers, so you need to check what’s there and change those if needed. All depends how you’re going to use it.
royhen99
Has thanked: 22 times
Been thanked: 137 times
Re: Simp BMS
Post by royhen99 »
In the version I did for Teensy 4.0 I moved OUT5 and OUT6 to pins 3 and 4 as they were on the can bus pins ( 22 and 23 )
marucha79
Re: Simp BMS
Post by marucha79 »
Ok, I'll check pins more carefully. Could you @royhen99 tell something more about your design?
royhen99
Re: Simp BMS
Post by royhen99 »
Code was very similar to that posted by mane2. Hardware was Skpang triple can board, just used for Initial testing and balancing of BMW battery pack.
marucha79
Re: Simp BMS
Post by marucha79 »
Well, it looks like very good hardware solution, need just make PCB for input and output protection.
mane2
Re: Simp BMS
Post by mane2 »
royhen99 wrote: ↑Sun Dec 15, 2024 8:12 pm In the version I did for Teensy 4.0 I moved OUT5 and OUT6 to pins 3 and 4 as they were on the can bus pins ( 22 and 23 )
Good point, missed that. Updated the repo.
mane2
Re: Simp BMS
Post by mane2 »
marucha79 wrote: ↑Mon Dec 16, 2024 7:05 am Well, it looks like very good hardware solution, need just make PCB for input and output protection.
I just got 8 port optocoupler and 8 port relay module as I don't have any experience on making PCBs. Would you mind of sharing your design once it's ready?
marucha79
Re: Simp BMS
Post by marucha79 »
I've just bought Skpang triple can board, so I'll prepare only protection board. My design are rather primitiv and I prefere THT technology, but I don't mind sharing it when it will be done of course.
EmptyCarts
Re: Simp BMS
Post by EmptyCarts »
tom91 wrote: ↑Fri May 03, 2019 10:20 pm
Hey tom91 - Wanted to see if SimpBMS will ever be open source? Or was the license sold to Vero? Because $900 seems VERY steep in price...
If not then is there any current resellers? I am looking for the latest SimpBMS board.
Re: Simp BMS
EmptyCarts wrote: ↑Thu Jan 16, 2025 1:16 am Hey tom91 - Wanted to see if SimpBMS will ever be open source? Or was the license sold to Vero? Because $900 seems VERY steep in price...
It is. https://github.com/Tom-evnut/TeslaBMSV2
Hardware is pointless as the Teensy 3.2 is no longer made.
Keep in mind what you are paying for. If you got no skills to debug program or make boards yourself.
Jiyar
Re: Simp BMS
Post by Jiyar »
marucha79 wrote: ↑Mon Dec 16, 2024 8:48 am I've just bought Skpang triple can board, so I'll prepare only protection board. My design are rather primitiv and I prefere THT technology, but I don't mind sharing it when it will be done of course.
Can you please share your protection board design with me also, I will appreciate your help.
I tried to modify TeslaBMS V2 for teensy 4.1 based on mane2 code.
X19e
Re: Simp BMS
Post by X19e »
I'm interpreting CANbus data from my SimpBMS. The manual says that 0x35A Warning should send these Datas:
But in the TESLABMSV2.ino project I found a more complex definition, that maybe is related to a Victron system I didn't use:
msg.id = 0x35A;
msg.len = 8;
msg.buf[0] = alarm[0];//High temp Low Voltage | High Voltage
msg.buf[1] = alarm[1]; // High Discharge Current | Low Temperature
msg.buf[2] = alarm[2]; //Internal Failure | High Charge current
msg.buf[3] = alarm[3];// Cell Imbalance
msg.buf[4] = warning[0];//High temp Low Voltage | High Voltage
msg.buf[5] = warning[1];// High Discharge Current | Low Temperature
msg.buf[6] = warning[2];//Internal Failure | High Charge current
msg.buf[7] = warning[3];// Cell Imbalance
Can0.write(msg);
What do I want to do? My Controller expects a LIMIT signal to reduce the output of the system if the BMS signals it has to reduce the discharge output.
My interpretation is that 'Undervoltage' and 'Overtemp' would be the correct Warning Signals to introduce a LIMIT mode of my motor controller. The difference between manual (0.29) and Code TESLABMSV2.ino makes me wonder if I'm correct. Can you answer this, please?
Best regards
Frank
PS: I wrote in another post that I want to rebuild the firmware for SimpBMS myself and modify the data send on Canbus. I skipped this idea and use the standard script for Tesla. A proxy Controller that I use to display information on the dashboard reads all information via Canbus from SimpBMS and finally send it in the required format to my Motor Controller.
Re: Simp BMS
X19e wrote: ↑Tue Feb 25, 2025 9:53 am My interpretation is that 'Undervoltage' and 'Overtemp' would be the correct Warning Signals
Yes if you use the warning ones and not the alarm ones.
///warnings///
  warning[0] = 0;
  if (bms.getHighCellVolt() > (settings.OverVSetpoint - settings.WarnOff))
    warning[0] = 0x04;
  if (bms.getLowCellVolt() < (settings.UnderVSetpoint + settings.WarnOff))
    warning[0] |= 0x10;
  if (bms.getHighTemperature() > (settings.OverTSetpoint - settings.WarnToff))
    warning[0] |= 0x40;
  warning[1] = 0;
  if (bms.getLowTemperature() < (settings.UnderTSetpoint + settings.WarnToff))
    warning[1] = 0x01;
X19e
Re: Simp BMS
Post by X19e »
tom91 wrote: ↑Tue Feb 25, 2025 11:34 am Yes if you use the warning ones and not the alarm ones.
That was my approach. Maybe I should add LowTemperature for the Limit specification. But first: TEST.
Thank's a lot for your fast response, the complete definition for 0x35A and the corresponding code snippet.
Have a nice day!
Frank
Jiyar
Re: Simp BMS
Post by Jiyar »
mane2 wrote: ↑Sun Dec 15, 2024 7:08 pm Here's a link to quickly converted Teensy 4.1 version of SimpBMS BMWPhevBMS https://github.com/amattila/BMWPhevBMS-Teensy41
Hi mane2,
Could you please send me the FlexCAN_T4.h library link that you used for your code
The current version has been modified and gives a bunch of errors when I try to compile and upload the code.
I really appreciate your help.
mane2
Re: Simp BMS
Post by mane2 »
Jiyar wrote: ↑Sun Mar 02, 2025 10:42 am Hi mane2,
If you clone the repo, open it with VS Code and have PlatformIO installed, it pulls the required libraries and compiles successfully without any modifications. Just tested.
