Thanks, Philipjohu wrote: ...
Gen 3 160kw inverter only outputs 125 kw
- Zapatero
- Has thanked: 25 times
- Been thanked: 43 times
I have installed a Gen3 inverter and it only outputs 125Kw. I kindly like to ask Johannes to paste the line of code here so someone maybe can identify the issue.
- Has thanked: 454 times
- Been thanked: 1771 times
Re: Gen 3 160kw inverter only outputs 125 kw
In general the gremlin would be in this file: https://github.com/damienmaguire/Stm32- ... eafinv.cpp
And possibly this line:
So maximum request is 2047
final_torque_request = (torquePercent * 2047) / 100.0f;Support R/D and forum on Patreon: https://patreon.com/openinverter - Subscribe on odysee: https://odysee.com/@openinverter:9
- dimonlipko
- Has thanked: 7 times
- Been thanked: 11 times
I have the same problem. I add more ID in can bus that need for 160kw inverter, and it start take 550A from battery. But now have problem, that when torque request more than 2047, motor cut power and shaking. If I press pedal slower, motor have full power, but without max torque.
- Zapatero
Are there some can logs out there from a Nissan Leaf with 160Kw where we could see, what exactly is happening there?
- dimonlipko
- Zapatero
can you please tell me which message contains the value?johu wrote: ↑Fri Dec 02, 2022 6:44 am In general the gremlin would be in this file: https://github.com/damienmaguire/Stm32- ... eafinv.cpp
And possibly this line:So maximum request is 2047Code: Select all
Hex-Identifier and Start bit and length.
Then i could check the text file for the values.
Thanks!!!
- Zapatero
In 1D4 byte 0 and 1 according to the VCU code we're seinding 0xF7 and 0x07.
Seems to be 0x88 most of the time in the can log txt file.
On another website i found it should be 0x6e and 0x6e
// Usually F7, but can have values between 9A...F7 (gen1)
bytes[0] = 0xF7;
// 2016: 6E
// outFrame.data.bytes[0] = 0x6E;
// Usually 07, but can have values between 07...70 (gen1)
bytes[1] = 0x07;
// 2016: 6E
//outFrame.data.bytes[1] = 0x6E;
https://mynissanleaf.com/viewtopic.php? ... &start=190
byte send1D4[8] = {0x6e, 0x6e, 0x00, 0x00, 0x00, 0x44, 0x01, 0x00};
bytes[0] = 0xF7;
// 2016: 6E
bytes[1] = 0x07;
// 2016: 6E
Also looked at the logfile now. Torque request is in bytes[2] and bytes[3] & 0xF0, signed, big endian
So torque = -2048*(bytes[2] & 0x80)/0x80 + (bytes[2] & 0x7F) * 16 + bytes[3] / 16
The largest value I ever see in the logfile is 1360, very stable for a prolonged time, so probably full throttle. Or have I miscalculated somehow and it should be 1360*2?
- dimonlipko
aesthetect
- Has thanked: 4 times
Is operation smooth and consistent below request of 2047?
I assume this would be the same situation on any complete 160 kW gen 3 motor+inverter? But is a non-issue on 110 kW units?
- Zapatero
Yes, drives perfectly smooth, just only delivers 125 kw
- Zapatero
No, the topic is about the 160kw inverter. How the 110 kw inverter behaves i don't know.
