Wanted set of 6 BMW phev bms slaves
Ev8
Has thanked: 43 times
Been thanked: 163 times
Post by Ev8 »
As above, looking for a set of 6 bmw phev bms slaves from the 9kwh 6 module battery, I have plenty from the 5 module pack but in order to add a 6th to my current 5s pack I need modules from the 6s pack so I don’t double up of can addresses
Has thanked: 217 times
Been thanked: 608 times
Re: Wanted set of 6 BMW phev bms slaves
Are you looking for the Gen 1 slaves? You can renumber the Gen 1 can only slaves, renumbering code is in the SimpBMS code.
https://github.com/Tom-evnut/BMWPhevBMS ... hevBMS.ino
Ev8
Post by Ev8 »
Thanks Tom I was aware that you could renumber them but didn’t realise they were identified by number and not unique id’s, and figured as I only had slaves from 5 module packs I’d end up with a duplicated Id, I’ll have to take a proper look at the code
FFMan
Has thanked: 8 times
Been thanked: 47 times
Post by FFMan »
or use a teensy and put then on separate can channels
E46 touring
BMW 9kwh & 12kwh packs
