My BMW has a simple loop of pipe in front of the radiator that the power steering fluids runs through as a simple cooler.
For a road car running in the UK is his necessary. The pipes are in the way, and i wonder whether i bother to relocate the cooler or delete it ?
I'm using a zafira electric PS pump in my convernsion.
Power steering cooler
- Has thanked: 83 times
- Been thanked: 428 times
Re: Power steering cooler
My beetle had one too, 12k miles later my zafira pump it still running fine. For my current project, a BMW E91, Ive changed to an electric rack instead.
- Has thanked: 220 times
- Been thanked: 178 times
It's hard to know how efficient the zafira pump is. But if it did not have a cooler line originally you might be able to eliminate it.
Personally I would try to reroute the cooler line and keep it. I've had the power steering fluid boil over in one of my track cars, had to add a cooler after it was built.
