Main Page Old
Before you begin:
The Open Inverter projects consists of a core development project around an open source inverter, a power stage, taking the DC current provided from a battery and converting it to a controlled signal to drive AC and PMSM motors.
The project has also spawned additional projects that take existing OEM Power Stages/Inverters from cars, which having been made in bulk and are now cheaply and readily available, and provides a means of upcycling and taking control of them so they can be used in conversion projects.
There are also additional projects and discussions in the forums for components beyond the power stage, such as Battery Management Systems, Motors, Batteries, etc.
Combined these projects and discussions and the community effort on this wiki and on the forums aim to make converting existing internal combustion engine (ICE) vehicles, a cheap and easy proposition for individuals, and companies, looking to specialise in converting ICE vehicles.
The open inverter project consists of three main aspects:
Getting Started
Inverter variants available:
Open Inverter (Core Project) |
| This is the kit provided to build your own power section,
meaning sourcing and constructing your own IGBTs and other components. |
This is the kit/boards for use with existing power sections,
meaning inverters sourced from OEM parts taken from existing cars, etc. and utilising the components within them. | |
Open Inverter Hardware |
Tesla Small Drive and Large Drive Units:
| New inverter testing
Light bulb test |
Open Inverter Software |
Auris/Yaris Inverter:
| Nissan Leaf VCM:
this vehicle control board plugs into the Nissan Leaf inverter externally and controls it via CAN | ||
Use inverter as a battery ChargerBoth the open inverter and some OEM inverters can be used as a battery charger, further saving on component costs. You can read more about how the open inverter and the theory of charging here | ||
Further Components
- Motors
- Batteries
- Charger
- DC/DC Converter
- HV Junction Box
- Other various components
- Vacuum Pumps
- Heaters
- Air Conditioning
- Information Displays
- etc.
FAQs
Open Inverter CAN std.
Glossary of Terms
Legalities
