Category:Nissan
Revision as of 12:29, 24 August 2024 by Wrobelda (talk | contribs) (Added info on 4WD e-power variant, which uses the MM48 engine in rear axle.)
LEAF
Components
  • gearbox
  • inverter
  • charger
  • DC-DC converter
  • heaters
Reusing LEAF components
Other Nissan powertrains
Nissan Fuga Y51 Hybrid/Infiniti M Q70 Hybrid
  • The Nissan FR Hybrid transmission is made by Jatco and includes a single 60 kW motor integrated into a 7 speed automatic transmission that has a RWD layout. It's the Jatco JR712E.
Nissan Altima
  • The Nissan Altima used Toyota's Hybrid Synergy Drive (likely GEN 2 Prius) system.
Nissan e-power Hybrid system
  • The e-Power Hybrid system borrows the 80 kW EM57 from the Nissan Leaf, and pairs it with a 1.2L 3 cylinder engine (HR12DE, a variant of Nissan HR engine adapted for serial hybrid use) hooked up to a generator that can power the EM57 and feeds power into a 1.57 kWh Li-ion battery pack. In 4WD configuration, the rear axle uses additional MM48 engine (https://www.youtube.com/watch?v=FmdtLZkHZOk). The e-power Hybrid System is commonly used in the Nissan Note and Nissan Serena, amongst others, which are primarily sold in Japan and the US, and some other markets as imported by low volume importers, and the Nissan Kicks in Thailand. Includes an inverter, but no charger.
Other Nissan Hybrid Drivetrains
  • The Jatco CVT8HB Hybrid transmissions was also used by Nissan in Japan.
