Toyota Prius Gen2 Inverter
Revision as of 21:49, 23 September 2022 by MattsAwesomeStuff (talk | contribs)
Prius Gen 2 Inverter Montage
  • Large part availability, Priuses have been made in large numbers for 20 years and spares are inexpensive.
  • Respectable performance. Rated for 50kW output, but tested to handle 600v, and 350+A for MG2 inverter, 250+A for MG1 inverter, 360kW total (480hp)
Replacement Controllers
32-pin Prius Harness Pin Numbering
32-pin Prius Inverter Colors
32-pin Prius Inverter Harness Connections
32-pin Prius Inverter i9 12v DC
32-pin Prius Inverter Harness Cables
(Inverter Side)
(See pictures to the right)
Wire Color
(Harness Side)
1 vacant
2 GIVA MG1 Phase Current V LightGreen White - Cable 1
3 GIVB MG1 Phase Current V Purple-Red Black - Cable 1
4 GUU MG1 PWM U - Speed Signal Wave Blue Black - Cable 2
5 GVU MG1 PWM V - Speed Signal Wave Blue-Red Green - Cable 2
6 GWU MG1 PWM W - Speed Signal Wave Yellow Yellow - Cable 2
7 MIVA MG2 Phase Current V LightGreen-Black Green - Cable 3
8 MIVB MG2 Phase Current V Purple-Yellow White - Cable 3
9 MUU MG2 PWM U - Speed Signal Wave Blue-Black Black - Cable 4
10 MVU MG2 PWM V - Speed Signal Wave Blue-Yellow White - Cable 4
11 MWU MG2 PWM W - Speed Signal Wave Yellow-Black Red - Cable 4
12 VH Inverter Capacitor Voltage Purple Yellow - Cable 3
13 CPWM Boost converter PWM switch signal Blue Black - Cable 5
14 CT Boost converter temperature sensor Green-Red Red - Cable 5
15 VL Boost converter input voltage Purple-White Yellow - Cable 5
16 GINV Inverter Ground Black-White Yellow - Cable 4
17 vacant
18 GIWA MG1 Phase Current W Grey Red - Cable 1
19 GIWB MG1 Phase Current W Grey-Black Green - Cable 1
20 GSDN MG1 Shutdown Brown-Black Red - Cable 2
21 GIVT MG1 Inverter Temperature Green-Black White - Cable 2
22 GFIV MG1 Inverter Fail White-Grey Grey
23 MIWA MG2 Phase Current W Grey-Green Red - Cable 3
24 MIWB MG2 Phase Current W Grey-Red Black - Cable 3
25 MSDN MG2 Shutdown Brown Green - Cable 3
26 MIVT MG2 Inverter Temperature Green Light Blue - Cable 4
27 MFIV MG2 Inverter Fail White Green
28 OVH Overvoltage Pink Brown
29 CSDN Boost converter shutdown signal Brown-White White - Cable 5
30 FCV Boost converter fail signal White-Red White
31 OVL Boost converter over voltage signal Pink-Blue Black
32 GCNV Boost converter ground Black-Red Green - Cable 5
(Article continues below)
DC-DC Converter
Prius Gen2 DC-DC connections.
1 IGCT 12v+ Blue
2 ID1 Not Needed Purple
3 S B+ (opt) White
4 NODD 0-5v+ Ppl/Gld
5 VLO Not Needed Blue
6 Vacant
Inverter Cooling
Wiring
Connector Male Female
C5 90980-10988 90980-10987
B+ (DC-DC output) 90980-11963
32-pin connector TE 1318747-1 (& 1123343-1 for pins)
28-pin connector (on inverter logic board) TE 1565380-1 (& 1123343-1 for pins)
Charging
Relevant Parameters
Charge mode:Buck
Chargecur: 1.5
Chargekp 20
Chargeki: 10
Chargeflt 2 dig
Relevant Pins
  • CSDN (pin 29 on inverter)
    • Shuts down high and low IGBTs when fed 12v, via 470R
    • When CSDN is HIGH both IGBTs are OFF.
  • CPWM(pin 31 on control board, 13 on inverter)
    • Enables charge mode when fed 12v via 470R
    • When CPWM is HIGH, the LOW side IGBT is on(shorts out battery), when CPWM is LOW the HIGH side IGBT is on.
  • Forward and reverse (11 and 12 on control board)
    • Both must be high to enable charging
  • DCSW switch(15 in control board)
    • Controls DC relay switch.
Physical setup
  • 240v AC plugs into two MG1 phases, with a precharge resistor always on.
    • Relay controlled by DCSW pin connected to ground side of relay signal wires.
  • HV Battery connected with precharge resistor
    • Relay controlled from DCSW pin connect to ground side of relay wires.
  • CPWM to 12v via 470R resistor. Pulled high to when you want to charge
  • CSDN pin to 12v via 470R resistor. Pulled high to when you want to charge
    • CSDN pin also tied to DCSW signal pin, which pulls it down when precharge is complete.
Process
  1. Fwd and reverse signals high, relays open
  2. CPWM and CSDN pulled high via 470R .
  3. Connect AC input voltage with precharge
    1. DCSW will then close relays and pull down CSDN pin to activate charging.
  4. Activate buck on charger. (By manual web interface or does just having FWD and Reverse high activate this?
  5. To stop, can change chargecur to 0 or switch off inverter power.
Offgrid AC Use
See: https://openinverter.org/forum/viewtopic.php?p=22886
