Main Page Old
Revision as of 11:32, 15 June 2020 by Clanger9 (talk | contribs) (→‎Open Inverter CAN std.: Add link to new getting started guide for CAN bus and Arduino Uno)
Before you begin:
The Open Inverter projects consists of a core development project around an open source inverter, a power stage, taking the DC current provided from a battery and converting it to a controlled signal to drive AC and PMSM motors.
The project has also spawned additional projects that take existing OEM Power Stages/Inverters from cars, which having been made in bulk and are now cheaply and readily available, and provides a means of upcycling and taking control of them so they can be used in conversion projects.
There are also additional projects and discussions in the forums for components beyond the power stage, such as Battery Management Systems, Motors, Batteries, etc.
Combined these projects and discussions and the community effort on this wiki and on the forums aim to make converting existing internal combustion engine (ICE) vehicles, a cheap and easy proposition for individuals, and companies, looking to specialise in converting ICE vehicles.
The open inverter project consists of three main aspects:
Getting Started
Inverter variants available:
Open Inverter (Core Project)
Open Inverter Related Projects / Control Boards
This is the kit provided to build your own power section,
meaning sourcing and constructing your own IGBTs and
other components.
This is the kit/boards for use with existing power sections,
meaning inverters sourced from OEM parts taken
from existing cars, etc. and utilising the components
within them.
Open Inverter Hardware
Tesla Small Drive and Large Drive Units:
commonly there is a large drive unit and small drive unit available.
These combine the inverter and motor into a single package. The
control boards for these replace the existing control board within them.
Lexus GS450h Inverter / VCU:
the GS450h provides a gearbox (where the motors are located)
combined with the original inverter, this board looks to control
the inverter and the gearbox itself to provide a powerful set up
suitable for rear wheel drive set ups, replacing the existing
longitudinally mounted gearbox.
Prius Generation 3 Inverter:
a cheap available inverter from the popular Prius hybrid, this
Open Inverter Software
Auris/Yaris Inverter:
similar to the Prius board, there's subtle differences between them and
therefore the need for a separate board.
Nissan Leaf VCM:
this vehicle control board plugs into the Nissan Leaf inverter externally
and controls it via CAN
CAN communication
Both the open inverter and some OEM inverters can be used as a battery charger, further saving on component costs. You can read more about how the open inverter and the theory of charging here
Further Components
FAQs
Glossary of Terms
Legalities
Conversion Projects
OEM Parts
