Convert a 18 ft boat to electric
Colm Spain
Hi all, I am planning to convert a Bow Rider 18ft ski boat to electric. I will be removing the Mercruiser 3L petrol engine 135 Hp and tank. Bought 2012 Leaf motor, inverter.Just started to get my head around wiring and controls.....but have a few questions, if anyone can help.
1. I am leaving the out drive Alpha One Leg and going to marry up the Leaf motor to the shaft.....will it work? Power of original engine to power of new motor? Not looking for high speed ,but good torque for take off. 24 kwh battery
2.Is the Pre charge resistor 100 watts and 100 ohms?
3. Size of main HV fuse.
Any advice will be welcome,
Thanks Colm.
Thanks Colm.
Colm Spain
Re: Convert a 18 ft boat to electric
Another question do I need the second main contactor on the negitive supply and is this the right part no. for the contactor EV200AAANA 1618002-7
Thanks.
Thanks.
- Bratitude
- Has thanked: 222 times
- Been thanked: 413 times
move this to the project section
Colm Spain
Slevb
Colm,
I have just started building two outboard engines form my electric catamaran, with Nissan leaf em57 and motor controller, thunderstruck vcu. Would be great to here how your project goes. Regards jamie
Colm Spain
Hi Jamie, My latest plan is to replace 3 litre inboard engine for leaf or Siemens motor, I was thinking of an OB but my requirements have steered me towards inboard. I have being doing a bit of research re. leaf and Siemens motors in boats , no data on the leaf and the Siemens is tried and tested, its a work horse. Using Damiens VCU to control the motor, Just bought a throttle {throttle position sensor] on ebay just waiting on it to arrive. Plan to use the original Throttle and gear shift in the boat. Its my first project so learning as I go, if I can do anything to help, do drop us a message.
Colm.
Colm.
Colm Spain
https://www.ebay.ie/itm/2004-CITROEN-XS ... GTR=1#shId
this is the link for the throttle, if it helps.
Sounds like a cool project!Colm Spain wrote: ↑Fri Dec 04, 2020 8:16 pm Hi all, I am planning to convert a Bow Rider 18ft ski boat to electric. I will be removing the Mercruiser 3L petrol engine 135 Hp and tank. Bought 2012 Leaf motor, inverter.Just started to get my head around wiring and controls.....but have a few questions, if anyone can help.
While I am certainly NOT an authority on the subject, some thoughts on the above and second HV relay question...1. I am leaving the out drive Alpha One Leg and going to marry up the Leaf motor to the shaft.....will it work? Power of original engine to power of new motor? Not looking for high speed ,but good torque for take off. 24 kwh battery
1) You may be able to take the drive plate off the engine and use the hub to verify fitment or make an adapter for the out drive.
2) The one I have, on a Leaf relay board, is 30 ohms
3) Depends on your power and voltage; Prius is like 125A, not sure about the Leaf
4) Most use a relay for both the HV + and HV-, I think doing so is VERY wise.
- Has thanked: 455 times
- Been thanked: 1771 times
Leaf 24 kWh pack has a 225A fuse
Here is a relay board from a Leaf.
Colm Spain
Hi, thanks for the reply and advise, will keep ye posted on the progress.
Colm.
Colm.
