EV car conversion hardware
Has thanked: 134 times
Been thanked: 337 times
arber333 wrote: Fri Aug 13, 2021 7:45 pm
Cookie6000 wrote: Fri Aug 13, 2021 7:28 pm Since I got the VAG sensor working, the GM one went down the priority list. Once I have the cluttered bench cleared of multiple mini tasks, I'll get back to it. I am pretty sure it was something simple I was missing
I jusr ordered one GM sensor. Will publish what i find out.
I tested the unexplored Bosch (GM) 0265 005 321 vac sensor. It has integrated check valve so you just install input hose on one side and output hose on the other.
It seems it is a 5V unit. I got it with connector and a pigtail. So i supply 5V to yellow/orange (pin 3) and black/yellow (pin 2) wires and i got response on the yellow/violet (pin 1) wire. When at outside pressure you get 600mV but if you supply underpressure you get analog voltage response. My testing was limited to a hose and UP28 pump but i still got over 3V result. Hope it helps.
But I decided I will stick to my Volvo switch P/N 30645383 since it is really simple to use.
It is digital on off and it also has a check valve. Did i mention i can find it really cheap too...
https://rrr.lt/en/search?q=30645383&exact=1
TonyV
Been thanked: 12 times
Post by TonyV »
Damien used a driveshaft from a BMW 735i
North America I don't think the 735i was ever sold here.
This might be old news but, I can confirm that a 2006 BMW 750i driveshaft will bolt up to the 450H transaxle.
Centre plastic bushing will need to be drilled out using a 5/8" drill bit.
Just like Damien said.
TonyV
Post by TonyV »
My attempt at making a driveshaft for my convert 2006 e46 using the Lexus 450H trans.
I'm sure it won't work for most but, it might give ideas to others.
Disclaimer:
Work preformed from a dumbass(me) in a home garage.
This is for educational purposes only. :)
DaveH
Been thanked: 11 times
Post by DaveH »
Can anyone who knows about throttle pedals steer me in the right direction to locate a suitable pedal for my VW bus? I need a floor mounted type like a BMW one but I'm not sure what is going to need the least amount of modding/fabrication or will give me a suitable operating position. I don't have any photos right now but the cab floor is flat with a slight bend upwards at the front. At full travel the pedal is almost horizontal. Should I be looking for something from a truck rather than a car?
DaveH wrote: Mon Oct 25, 2021 2:20 pm Can anyone who knows about throttle pedals steer me in the right direction to locate a suitable pedal for my VW bus? I need a floor mounted type like a BMW one but I'm not sure what is going to need the least amount of modding/fabrication or will give me a suitable operating position. I don't have any photos right now but the cab floor is flat with a slight bend upwards at the front. At full travel the pedal is almost horizontal. Should I be looking for something from a truck rather than a car?
I recommend you start at the beginning of this very thread with toyota pedals.
viewtopic.php?p=3772#p3772
I like the Auris one because you can cut and weld the pedal to your liking.
You can also make your own ramp for throttle mounting.
https://leafdriveblog.wordpress.com/tag/throttle/
DaveH
Post by DaveH »
Thanks arber but I can't use that kind of pedal. I don't have a firewall or wheel arch at the front of the cab, just a horizontal floor.
DaveH wrote: Mon Oct 25, 2021 3:16 pm Thanks arber but I can't use that kind of pedal. I don't have a firewall or wheel arch at the front of the cab, just a horizontal floor.
Like i said, you can make your own pedal adapter/slope out of wood or weld it from sheet metal.
bobby_come_lately
Has thanked: 41 times
Been thanked: 40 times
Post by bobby_come_lately »
I'm using the 1-series pedal Dave. Very simple to use with two 5v outputs. I 3D-printed an adaptor plate that allows it to sit in the original mounting position for the old analogue pedal in my Z3. I also have a design for an adaptor for flat floor mounting that I use in my test setup - see pic. Happy to share that design or send you one if you don't have a 3D printer?
DaveH
Post by DaveH »
bobby_come_lately wrote: Thu Oct 28, 2021 6:49 am I'm using the 1-series pedal Dave. Very simple to use with two 5v outputs. I 3D-printed an adaptor plate that allows it to sit in the original mounting position for the old analogue pedal in my Z3. I also have a design for an adaptor for flat floor mounting that I use in my test setup - see pic. Happy to share that design or send you one if you don't have a 3D printer?
Thanks for the kind offer. I've ordered an E46 pedal now, with the mounting bracket (they seem very common). I might not need any kind of adapter if I use the bracket, but we'll see when I get the vehicle back and start looking at it.
There is a really cheap pump with good input vs output angle setup:
https://www.ebay.de/itm/283846097712
Also connector for it:
https://www.ebay.de/itm/233857905986
I am using theese heat shrink sleeves to extend sensor wires when in tight places.
Otherwise i use plummers paste, solder and shrinktube.
It can be bought from aliexpress or ebay...
https://www.aliexpress.com/item/1005003 ... 1200_1&s=p
crasbe
Has thanked: 47 times
Been thanked: 150 times
Post by crasbe »
I can't recommend using those. This is what they looked like on my friend's Volvo V70 after just two years. It was used to connect a new pig tail for the temperature sensor.
It is not in a very hot place and still the tubing became brittle. The flux inside started to corrode the wires and the soldering connection was very poor, but that was not visible from the outside.
I had to cut the wire, clean the residue of the shrink tubing, solder and shrink tube it again. In the end it cost more time than it saved.
Maybe they're better when you can get them in decent quality, but I don't think you get that from Aliexpress.
crasbe wrote: Sat Jan 08, 2022 6:37 pm I can't recommend using those. This is what they looked like on my friend's Volvo V70 after just two years. It was used to connect a new pig tail for the temperature sensor.
Hm... that would be bad. I can only say i use them for 2 years now and i allways put them into a heatshrink sleeve or those white electrical tubes.
Havent had a problem up to date. Not saying there wouldnt be...
When my Webasto EVO control board broke and after i tried to fix it unsuccessfuly i searched online for spare board.
Surprisingly i found that in neighbouring Hungary:
https://norx.hu/
He seems to sell replacement boards for various Webasto coolant heaters and he has done away with Webasto timer. It only needs a switch to start the heater. Diagnostic is still through W-bus.
Has thanked: 176 times
Been thanked: 369 times
found this canbus switch board https://www.ecumaster.com/products/can-switch-board/
pretty neat and simple little board, dont have to program it to get it sending messages.
8 analog inputs and 4 outputs
seems like a prefect companion for OI
I am getting my LIN bus module test board shortly. I dont have any info on its software.
https://www.ebay.de/itm/313274783224?_t ... %7Ciid%3A1
I wonder what others are using?
TNX
I got 2x Gigavac GV200 contactors from Jag Ipace that pull 3A each! Obviously they were run by a central circuit somewhere. To fully use them i would have to drop voltage and feed them PWM. But i dont want to reinvent the wheel.
Does anyone have a schematic for 12V contactor economizer?
EDIT: I have found an application UC that could work. TI DRV103 could drive 3.5A relay coil for a moment and then switch to PWM. Time and PWM parameters could be preset and circuit would run from direct external power.
https://www.ti.com/lit/ds/symlink/drv10 ... 1743890684
I will make one or two examples for testing, but if someone has any experience with that chip please share.
tnx
alexbeatle
Has thanked: 71 times
Been thanked: 29 times
Post by alexbeatle »
arber333 wrote: Fri May 06, 2022 7:48 am I got 2x Gigavac GV200 contactors from Jag Ipace that pull 3A each! Obviously they were run by a central circuit somewhere. To fully use them i would have to drop voltage and feed them PWM. But i dont want to reinvent the wheel.
tnx
Don't GV200Mxx contactors come with the internal PWM? https://www.gigavac.com/sites/default/f ... /gv200.pdf
alexbeatle wrote: Tue Jun 07, 2022 6:18 pm
Nope... i got them from Jag battery box, so they must have had some proprietary economizer...
Ev8
Has thanked: 43 times
Been thanked: 163 times
Post by Ev8 »
Not technically an ev part but I’ve discovered a useful size radiator for a conversion that can be bought new for as little as £35 (40euro)
Comes from a fiat cinquecento
Ev8 wrote: Thu Jun 16, 2022 6:53 pm Not technically an ev part but I’ve discovered a useful size radiator for a conversion that can be bought new for as little as £35 (40euro)
Yes i use the same fiat 500 radiator from 1988 in my peugeot to cool motor, inverter and chargers. 😎
Edit: mine has also integral coolant tank which i use to deair the system.
zippy500
Has thanked: 76 times
Post by zippy500 »
Is a Radiator fan required ?
ohh this looks perfect, what year?
Ev8
Post by Ev8 »
Was listed as
FIAT CINQUECENTO, SEICENTO, 600, KIT CAR 0.9 1.1 MANUAL RADIATOR 1991 TO 2010
chentron
Has thanked: 42 times
Been thanked: 10 times
Post by chentron »
I have a MES-DEA 70/6E2, never use it.
Only have a paper from maker, connector it is just a 12v pin but i dont find the pinout.
somebody know which is the positive and negative here ?
arber333 wrote: Thu Oct 15, 2020 6:54 pm Here are some brake boost pumps for which i know are certified to pass TUV.
MES-DEA 70/6E2
https://evshop.eu/en/vacuum-pumps/58-mes-dea-706e2.html
https://evshop.eu/en/index.php?controll ... achment=23
Hella UP28
Found in various Audi, VW and Volvo cars
https://www.hella.com/microsite-electro ... s-116.html
http://hellahd.com/index.php/default/el ... roduct-11/
Hella UP30
I found that in a Renault Megane car. I use this in my conversion and is quite powerfull.
https://www.hella.com/microsite-electro ... p-117.html
The real problem i see is using brake switch. I think we would need more variation of them.
I had a problem with Dracarys switch. It is easy to use, but it is terribly unreliable.
https://www.amazon.co.uk/Dracarys-Acces ... B07H9664YM
It locks off at random. I found it is good to spray some WD40 into the switch before installation. But still when it goes dry membrane still sticks. I will try MIG welding spatter spray next...
Then i will replace it with this: PSF109S-81-330 switch
https://uk.farnell.com/multicomp/psf109 ... PSF%20109S
There is also this switch available: Volvo Booster Vacuum Switch 30645493 or 30645383. I need to test it yet...
https://www.fcpeuro.com/products/volvo- ... o-31265825
