question about bidir pedal control
- Romale
- Has thanked: 346 times
- Been thanked: 101 times
hello, people! I have such a question, in the case of using bidir mode, is it possible to hold the hill in both directions or not?
evil neodymium
- Romale
Re: question about bidir pedal control
also, do I understand correctly that the average value of the throttle should output 1.65 volts, the maximum forward 3.3 volts, and the maximum backward 0 volts?
evil neodymium
- Been thanked: 1918 times
Not tested, but in theory it should do just that.
No, calibration as always, midpoint is 0 throttle
- Romale
strange. I connected a 5kohm variable resistor and the motor stands still when the middle position. I connected a voltmeter and yes, the voltage of the middle is 1.65 ! and a full 0 volt output (leftmost position) gives the maximum motor speed in the opposite direction
evil neodymium
- Romale
One more question in this direction. How do I enable the rotation speed control option, not the power? (this is important to me for use in a houseboat)
evil neodymium
- Romale
whatever experiments I did with the settings, I could not find the inclusion of this option.
evil neodymium
Ah it's in cruisemode=ThrottlePot
- Romale
- Romale
alas! if you make such a setup there, then the set of revolutions occurs in spurts. for example, I add a pedal by 15%, but instead of smooth operation, acceleration-brake-acceleration-brake is constant for two seconds each action. in any direction of rotation.
evil neodymium
Cruise control does not work well with an unloaded motor. You can try lowering speedflt to 0
- Romale
Throttle speed mode, throttle sets speed rather than torque (also for boats)
this part of the description interests me))
bidir mode works fine.
but he controls the moment. it is not very convenient for rotating the propeller under water.
the described ability to control the number of revolutions of the motor instead of the torque would be ideal.
but how to turn it on?
evil neodymium
cruise control = speed control
For a propeller it does work with speedflt=0 and speedkp=0.1, tested before on a boat.
- Romale
- Romale
it worked at speedkp 0.02 !
almost without hesitation.
Sorry, that cruise control stops working in this mode and it is necessary to make a control handle with a rigid fixation.
However, thanks anyway!
the following tests with higher voltage and already on the water!
I hope the house will float soon
evil neodymium
- Romale
thanks again for the help with the settings. everything works fine!
evil neodymium
- Romale
Hello, guys!
I've lived to see the time when I needed BiDir mode and speed control again, not torque. And here's the trouble, the sadness, it was impossible to achieve rotation with the new foc firmware. Rollback to version 5.27 and everything works fine. So in the new firmware version (5.35 foc) something is broken with this mode.
evil neodymium
Did the inverter even go into run mode? I found a bug there that it only enters run mode when throttle is in full reverse (i.e. status != PotPressed)
