For this experiment its good of course
Yeah... I made all the same mistakes and i am mechanical engineer
OK then. You measure from the point of the single bolt. This will be your 0 coordinate. You need to give me three coordinates in space for each of your mounting bolts on the side of the chassis. Orient your system to the direction the driver is facing. Also please make a drawing of the upper plate so i will have a plain for the mount.
https://leafdriveblog.wordpress.com/202 ... age-drive/
I've actually put the capacitor onto the transistor base, thereby the transistor is working in its linear region. Supposedly Tourans fuel tank sensor doesn't like PWM.
I agree! I intend to take my MIG rig with me next time and i will teach him few weld stepsMattsAwesomeStuff wrote: ↑Fri Jul 28, 2023 5:03 pm Johannes, you don't have a welder?
This should be remedied!
You can get cheap welders... really cheap nowadays.
As opposed to Sandy Munro I believe in "threaded fasteners"
Maybe that changes my belief
Don't suppose you could knock up a quick circuit sketch? Pwm'ing to ground bypassing a trim pot still oscillates. I've gone up to 20kHz but still jiggles. I struggle to understand transistors, can just about muddle my way to use them as a switch.
Well i also keep the faith in threaded fasteners as a good ME believer...
