ESP32 Based Chademo
- Has thanked: 82 times
- Been thanked: 424 times
Re: ESP32 Based Chademo
I did have to put a jumper in.
It doesn't have any analogue inputs, but you could add. You could also change the code to not require any current/voltage monitoring and trust the values the charger is saying, if you so wished.BMW E91 2006
Oh what is the resistor for?
Edit I just saw its on the CAN so its likely a 120 ohm resistor right?
Thanks.
-Arlin
It is a can terminator on the second can
You will want to use a shunt. The problem with the hall effect sensors is they don't 0 well. Where as a Shunt sends 0 voltage at 0 current so its always calibrated
Ok back to this. I think I found the problem. Is default IP for ESP32 should be 192.168.4.1 But mine is not defining the default serial.
I added this in the INO file. And got this in the serial printout on the Arduino screen.
Anyone know how to add a set IP address?
I have tried a 100w USB wall adapter with a short and thick USB cable. I have also done the 3.3 jumper wire and run it from a 1000a 12v batter and the 3.3v rail was solid
It seems to be wifi settings and maybe something else as the wifi connection is not easy to make and seems to jump in and out.
Is there a Bluetooth thing to shut off? Maybe I will try shutting Bluetooth off in my PC
And changing it to this. I got this.Arlin wrote: ↑Sat Sep 14, 2024 8:40 pm Ok back to this. I think I found the problem. Is default IP for ESP32 should be 192.168.4.1 But mine is not defining the default serial.
- Has thanked: 208 times
- Been thanked: 572 times
Wifi starts further down. so only have it print the IP towards the end of the setup() section.
Tried it this way as well. Still 0.0.0.0
Also do I need to change WiFi.begin("Beetle_CHademo", "Fia84grapu"), to something else?
-Arlin
-Arlin
In order for this to work do I simply log into the wifi that the board is displaying in the serial output?
I am getting stuck on this part. But I have been off of it for a while. I am just getting back to this now.
Thanks.
-Arlin
Sorry, I'm not really sure what you're asking.
Oh how to get the Web page to load from my PC so I can set the settings etc.
- Has thanked: 22 times
- Been thanked: 133 times
Assuming you have the the same version as on github, connect your wifi to ESP32-CHADEMO, password ChadMeO.
Then access the web page at 192.168.4.1 which is the default IP address for the ESP32 web server.
