- Has thanked: 76 times
- Been thanked: 21 times
nice, you just changed 9600 to 115200? no changes to the nextion display?
- Proton
- Has thanked: 188 times
- Been thanked: 48 times
So.... After I thought that my tesla charger works, now it shows fault on the 2 out of 3 inverers that I thought were running. They were only pushing about 1.8 amps and after about 2 hours I got "fault" error on the 2 working inverters.
I am looking now for a 3.3.or 6.6kw Chinese charger on Aliexpress.
This weekend if I have time I will try my 9mm tool and if that does not work I will move to the 308 tool. it is frustrating when you spent 700-800$ on this setup.
The boys are trained on all tools, but my daughter needs to start training on the 9mm.
- Proton
Octavius convinced me to check again before I used my metric tool and found out that this AC switch went out.
Now it is charging with 4 amps I tried to go higher but the inverter contractors keep going on and off. for now is good because is a thin AC cable and it is only 120V.
at least I am finally charging the battery.
on 120v ac if you pull more than 10amps AC, the voltage drops so low that the charger resets itself, and tries again.
- Has thanked: 382 times
- Been thanked: 1574 times
Always use the correct tools when working with HV
- Proton
Nice to see the battery charging.
Now that I know the slowness on the screen was caused by the baud rate, I need to add some info back.
