Main Page Old
Revision as of 02:37, 21 May 2022 by Asavage (talk | contribs) (Capitalsation of 'DC'.)
Welcome to the open inverter wiki, please take your time to read!
The open inverter community is growing and moving quickly.
Stay up-to-date with the latest developments and findings, please check out the forums
To edit the wiki, login with your forum credentials.
Before you begin:
Please take the time to read.
Developers of various projects are often bombarded with private messages and emails. Managing these emails and question is a extremely large undertaking. Please read, and take the time to understand the information available here and across the web if you don't understand a topic. Developers are not your personal support team!
Consider donating to the many developers that have made all this possible: www.patreon.com/openinverter, https://www.evbmw.com/, https://www.paypal.com/paypalme/celeron55
The information provided on this wiki and the support forums is intended as information only. The Open Inverter project and it's contributors take no responsibility for how you use the information contained within these pages, nor any liability for injuries, or death, that may result from your actions.
The open inverter project originates from Johannes Hübner designing/building his own open source AC motor controller, dubbed the "open inverter"
With the rising popularity/availability of hybrid and electric vehicles, there is a growing supply of high quality and relatively inexpensive parts from auto-wreckers.
  • EV conversion
  • Energy storage
  • Power generation
  • Charging infrastructure
  • etc.
  • Motor Controllers
  • 1-3 phase power converters
  • DC/DC converters
  • buck/boost converters
  • Battery Management Systems (BMS)
  • Vehicle integration
  • etc.
As a results, there is a growing collection of open source software and hardware designed for the never ending list of OEM parts.
such efforts include:
Getting Started
It is recommend reading the Glossary of Terms before continuing further.
EV conversions:
OEM Parts:
FAQ
mechanical design database
Designs for:
  • adapter plates
  • motor couplers
  • drive shaft flanges
  • battery mounts
  • etc.
Open Inverter Related Projects / Control Boards
core universal hardware and software components
ZombieVerter VCU Tesla Small Drive and Large Drive Units:
commonly there is a large drive unit and small drive unit available.
These combine the inverter and motor into a single package. The
control boards for these replace the existing control board within them.
Open Inverter Hardware
Lexus GS450h Inverter / VCU:
the GS450h provides a gearbox (where the motors are located)
combined with the original inverter, this board looks to control
the inverter and the gearbox itself to provide a powerful set up
suitable for rear wheel drive set ups, replacing the existing
longitudinally mounted gearbox.
Prius Generation 3 Inverter:
a cheap available inverter from the popular Prius hybrid, this
Open Inverter Software
Auris/Yaris Inverter:
similar to the Prius board, there's subtle differences between them and
therefore the need for a separate board.
Nissan Leaf Gen2 Board
replaces the nissan OEM logic board with a rev 3 openiverter main board
Ford ranger ev board
openinverter kit for the ford ranger ev
CAN communication
Parameter definitions can be found here: Parameters
Working parameter sets can be found in the openinverter parameter database
Open Inverter CAN std.
Legalities
Conversion Projects
