Main Page Old
The openinverter project mainly aims to reuse existing components from production electric vehicles. We also aim to give some general guidelines on how to convert a vehicle to electric drive.
Before you begin:
Please take the time to read.
https://www.paypal.com/paypalme/celeron55
Welcome to the open inverter community
Legalities
Different countries have different legislation, if you want your car to certified for the road in your country please take the time to review this section. It might save you going down the wrong direction and creating something that can never be driven, or incur costs.
The open inverter started as a scratch built inverter and control board led by Johannes Hübner who designed and built his open open source AC motor controller dubbed the "open inverter".
Since then, the community has established and documented hardware and software approaches to reuse OEM inverters with the Open control board, and has more recently started on controlling OEM inverters over CAN, a process which doesn't require replacing any internal parts.
- EV conversion
- Energy storage
- Power generation
- Charging infrastructure
- etc.
- Motor Controllers
- 1-3 phase power converters
- DC/DC converters
- buck/boost converters
- Vehicle integration
- etc.
such efforts include:
- Mainboard/brain replacement
- CANBUS/LINBUS
- Sync serial
- FlexRay
- PWM
- etc.
Hardware | Firmware | Web Interface |
The design and development of the control hardware based around an STM32F103 chip. This provides the control signals to the power stage and on to the attached components. | The development of the code that goes on the STM32F103 chips and determines, amongst other things what signals are sent to the power stage and the attached components. | Using an ESP8266 chip, the development of a simple web based interface to adjust the parameters on the firmware chip and to display values returned from the chip, for example motor speed (RPM). |
Getting Started
The Community is focused on the electrical systems required for an EV, and may not be best placed to assist with mechanical issues specific to your vehicle.
Glossary of Terms
EV conversions:
- Motors
- Inverter
- Batteries
- DC/DC Converters
- HV Junction Box
- Heaters
- HVAC
- Brake Assist
- Vacuum Pumps
- Electronic Brake Boosters
- Power Steering
- Rapid Charging
- VCU Comparison
- Shift Controlers
OEM Parts:
- BMW
- Chevrolet
- Ford
- Hyundai
- Isabellenhütte Heusler
- Land Rover/Jaguar
- Mercedes-Benz
- MG
- Mitsubishi
- Nissan
- Opel/Vauxhall
- Peugeot
- Renault
- Tesla
- Toyota/Lexus
- Volvo
Required skills/Knowledge
To perform a successful EV conversion, you may require the following skills and/or knowledge (this is not an exhaustive list)
FAQ
Mechanical Design Database
here you will find measurements, models, files, etc for a variety of components such as:
- adapter plates
- motor couplers
- drive shaft flanges
- battery mounts
- etc.
Cooling System Components
Water Pumps
https://openinverter.org/wiki/Water_Pumps
Coolant Fittings
https://openinverter.org/wiki/Coolant_Fittings
Coolant Valves
https://openinverter.org/wiki/Coolant_Valves
Open Inverter Projects
Description / Notes | |
ZombieVerter VCU | Designed around a matched pair of Inverter and Motor taken from the original OEM vehicle the ZombieVerter is there to make those two components believe they are still in the original vehicle and are fed necessary commands to act as if they still are and interpret and responses back from the equipment for feedback (regen / rpm / etc) |
Open Inverter Hardware
Quite flexible in its application. The Open Inverter can be used to build a custom inverter itself where you supply the high power and high voltage components to create your own inverter, or to be used as the basis to take over control of OEM inverters so that they can drive nearly any attached motor to that inverter. |
Open Inverter Software | Two of the more important software aspects to master are below. |
CAN communication
Open Inverter Related Projects (Control Boards/VCUs)
Project | Description / Notes |
Tesla Small Drive and Large Drive Units: | Commonly there is a large drive unit and small drive unit available from the Model S.
Lexus GS450h Drivetrain: | The GS450h contains a gearbox (where the motors are located).
Prius Generation 3 Inverter: | A cheap available inverter from the popular Prius hybrid, this
board goes inside that inverter and allows you to control the features of it. |
Auris/Yaris Inverter: | Similar to the Prius board, there's subtle differences between them
and therefore the need for a separate board. |
Nissan Leaf Gen2 Board | Replaces the nissan OEM logic board with a rev 3 openiverter main board |
Ford ranger ev board | openinverter kit for the ford ranger ev |
All Control Boards / OEM Inverters |
Open Inverter Renewables Projects
Recently added to the forums are projects and discussions around turning the Open Inverter project towards capturing, storing and using renewable energy.
