Main Page Old
Before you begin:
Open inverter is a sueit of open source hardware and software projects for building, modifying and controlling a variety of power electronics.
The projects started from Johannes Hübner building a opensource ac motor controller.
The project now has spanned over many different areas in ev and hybrid vehicles components, such as:
- AC motor controllers
- 1-3 phase power converters
- dc/dc converts
- buck/boost converters
- battery management systems
With the rising popularity and avalibity of hybrid and electric vehicles, there is a growing supply of parts. The open inverter community's goal is to repurpose many of these components for ev conversions and other projects.
The open inverter community is growing and moving quite quickly, to stay up-to-date with the latest developments and findings, please check out the forums
consider contributing to www.patreon.com/openinverter and to https://www.evbmw.com/
The open inverter motor controller project consists of three main aspects:
Hardware | Firmware | Web Interface |
The design and development of the control hardware based around an STM32F103 chip. This provides the control signals to the power stage and on to the attached components. | The development of the code that goes on the STM32F103 chips and determines, amongst other things what signals are sent to the power stage and the attached components. | Using an ESP8266 chip, the development of a simple web based interface to adjust the parameters on the firmware chip and to display values returned from the chip, for example motor speed (RPM). |
Getting Started
Inverter variants available:
Open Inverter (Core Project) |
This is the kit provided to build your own power section,
meaning sourcing and constructing your own IGBTs and other components. |
This is the kit/boards for use with existing power sections,
meaning inverters sourced from OEM parts taken from existing cars, etc. and utilising the components within them. | |
Open Inverter Hardware |
Tesla Small Drive and Large Drive Units:
Lexus GS450h Inverter / VCU:
Prius Generation 3 Inverter:
Open Inverter Software |
Auris/Yaris Inverter:
Nissan Leaf VCM:
this vehicle control board plugs into the Nissan Leaf inverter externally and controls it via CAN | ||
replaces the nissan OEM logic board with a rev 3 openiverter board for full control | ||
All Control Boards / OEM Inverters | ||
Use inverter as a battery ChargerBoth the open inverter and some OEM inverters can be used as a battery charger, further saving on component costs. You can read more about how the open inverter and the theory of charging here |
Further Components
- Motors
- Batteries
- Charger
- DC/DC Converter
- HV Junction Box
- Other various components
- Vacuum Pumps
- Heaters
- Air Conditioning
- Information Displays
- etc.
FAQs
Open Inverter CAN std.
Glossary of Terms
Legalities
