Main Page Old
Revision as of 08:18, 19 April 2021 by Johu (talk | contribs) (Added link to parameter database)
Before you begin:
Open inverter is a suite of open source hardware and software projects for building, modifying and controlling a variety of power electronics.
projects originates from Johannes Hübner building a opensource ac motor controller, dubbed the "open inverter".
The project now has spanned over many different areas in ev and hybrid vehicles components, such as:
  • AC motor controllers
  • 1-3 phase power converters
  • dc/dc converts
  • buck/boost converters
  • battery management systems
With the rising popularity and avalibity of hybrid and electric vehicles, there is a growing supply of parts. The open inverter community's goal is to repurpose many of these components for ev conversions and other projects.
The open inverter community is growing and moving quite quickly, to stay up-to-date with the latest developments and findings, please check out the forums
consider contributing to www.patreon.com/openinverter and to https://www.evbmw.com/
The open inverter motor controller project consists of three main aspects:
Getting Started
Inverter variants available:
Open Inverter Related Projects / Control Boards
core universal hardware and software components custom hardware and software designed to work with particular components.
which are based on the core open inverter hardware or software stack.
ZombieVerter VCU (Testing/Developement - NOT for sale at present) Tesla Small Drive and Large Drive Units:
commonly there is a large drive unit and small drive unit available.
These combine the inverter and motor into a single package. The
control boards for these replace the existing control board within them.
Open Inverter Hardware
Lexus GS450h Inverter / VCU:
the GS450h provides a gearbox (where the motors are located)
combined with the original inverter, this board looks to control
the inverter and the gearbox itself to provide a powerful set up
suitable for rear wheel drive set ups, replacing the existing
longitudinally mounted gearbox.
Prius Generation 3 Inverter:
a cheap available inverter from the popular Prius hybrid, this
Open Inverter Software
Auris/Yaris Inverter:
similar to the Prius board, there's subtle differences between them and
therefore the need for a separate board.
Nissan Leaf VCM:
this vehicle control board plugs into the Nissan Leaf inverter externally
and controls it via CAN
Nissan Leaf Gen2 Board
replaces the nissan OEM logic board with a rev 3 openiverter board for full control
CAN communication
The openinverter firmware uses a set of about 70 parameters to adapt it to different inverter power stages, motors and position feedback systems. Also it lets you calibrate the throttle pedal, change regenerative braking settings and so on. Working parameter sets can be found in the openinverter parameter database
Both the open inverter and some OEM inverters can be used as a battery charger, further saving on component costs. You can read more about how the open inverter and the theory of charging here
Further Components
FAQs
Open Inverter CAN std.
Glossary of Terms
Legalities
Conversion Projects
OEM Parts
