Main Page Old
Before you begin:
Please take the time to read. Many developers of various projects are often bombarded with private messages and emails. Managing all these emails and question is a extremely large undertaking. please read, and re-read the information available here and elsewhere on the web if you don't understand a topic. the core developers are not your personal support team. consider donating to these developers for their open source work!
The information provided on this wiki and the support forums is intended as information only. The Open Inverter project and it's contributors take no responsibility for how you use the information contained within these pages, nor any liability for injuries, or death, that may result from your actions.
The projects originates from Johannes Hübner building his own opensource ac motor controller, dubbed the "open inverter".
Now with the rising popularity and availability of hybrid and electric vehicles, there is a growing supply of high quality and relatively inexpensive parts from auto-wreckers.
The main goal of the openinverter community is to reverse engineer many of these components for use for a variety of projects such as ev conversion, energy storages, etc.
The Openinverter projects now span over many different areas surrounding PEV, HEV, and PHEV components, such as:
- AC motor controllers
- 1-3 phase power converters
- dc/dc converts
- buck/boost converters
- battery management systems
- etc
as a results there is a growing selection of open source software and hardware designed for a never ending list of OEM parts.
there is a variety of ways one can take control over these oem parts:
- replace the mother board/ "the brains"
- canbus/linbus
- sync serial
- flexray
- pwm
- firmware/software reprogramming
- ect
as a result there is many bespoke boards running the main openinverter software or other opensource code designed to replace OEM part mother boards.
this has lead to a large collection of different boards available. To unify many of these board development projects, the community is largely focused on making a variety of standard external VCU and replacement control boards which will handle the ever growing list of OEM components.
The open inverter community is growing and moving quite quickly, to stay up-to-date with the latest developments and findings, please check out the forums
consider contributing to www.patreon.com/openinverter and to https://www.evbmw.com/
Hardware | Firmware | Web Interface |
The design and development of the control hardware based around an STM32F103 chip. This provides the control signals to the power stage and on to the attached components. | The development of the code that goes on the STM32F103 chips and determines, amongst other things what signals are sent to the power stage and the attached components. | Using an ESP8266 chip, the development of a simple web based interface to adjust the parameters on the firmware chip and to display values returned from the chip, for example motor speed (RPM). |
Getting Started
Open Inverter (Core Project/s) |
core universal hardware and software components | ||
ZombieVerter VCU | Tesla Small Drive and Large Drive Units:
Open Inverter Hardware | ||
Lexus GS450h Inverter / VCU:
Prius Generation 3 Inverter:
Open Inverter Software |
Auris/Yaris Inverter:
Nissan Leaf Gen2 Board
replaces the nissan OEM logic board with a rev 3 openiverter main board | ||
Ford ranger ev board | ||
All Control Boards / OEM Inverters | ||
ParametersThe openinverter firmware uses a set of about 70 parameters to adapt it to different inverter power stages, motors and position feedback systems. Also it lets you calibrate the throttle pedal, change regenerative braking settings and so on. Working parameter sets can be found in the openinverter parameter database | ||
Use inverter as a battery ChargerBoth the open inverter and some OEM inverters can be used as a battery charger, further saving on component costs. You can read more about how the open inverter and the theory of charging here |
Additional Components
- Motors
- Batteries
- Chargers and charge controllers
- DC/DC Converters
- HV Junction Box
- Heaters
- Other various components
- Vacuum Pumps
- Heaters
- Air Conditioning
- Information Displays
- etc.
FAQs
Open Inverter CAN std.
Glossary of Terms
Legalities
Conversion Projects
- VW Polo 86C Conversion
- Touran Conversion
- toyota gt86 nissan leaf motor
- Porsche Boxster 986 Tesla conversion
- Further Projects on the forum
