Main Page
Welcome, please take the time to read!
Welcome to the open inverter wiki.
The open inverter community is growing and moving quickly. To stay up-to-date with the latest developments and findings, please check out the forums
To edit the wiki, login with your forum credentials.
consider donating to www.patreon.com/openinverter and to https://www.evbmw.com/
Before you begin:
Please take the time to read. Many developers of various projects are often bombarded with private messages and emails. Managing all these emails and question is a extremely large undertaking. please read, and re-read the information available here and elsewhere on the web if you don't understand a topic. the core developers are not your personal support team. consider donating to these developers for their open source work!
consider contributing to www.patreon.com/openinverter and to https://www.evbmw.com/
The information provided on this wiki and the support forums is intended as information only. The Open Inverter project and it's contributors take no responsibility for how you use the information contained within these pages, nor any liability for injuries, or death, that may result from your actions.
The projects originates from Johannes Hübner building his own opensource ac motor controller, dubbed the "open inverter".
Now with the rising popularity and availability of hybrid and electric vehicles, there is a growing supply of high quality and relatively inexpensive parts from auto-wreckers.
The main goal of the openinverter community is to reverse engineer many of these components for use for a variety of projects such as ev conversion, energy storages, etc.
The Openinverter projects now span over many different areas surrounding PEV, HEV, and PHEV components, such as:
  • AC motor controllers
  • 1-3 phase power converters
  • dc/dc converts
  • buck/boost converters
  • battery management systems
  • etc
as a results there is a growing selection of open source software and hardware designed for a never ending list of OEM parts.
there is a variety of ways one can take control over these oem parts:
as a result there is many bespoke boards running the main openinverter software or other opensource code designed to replace OEM part mother boards.
this has lead to a large collection of different boards and software. To unify many of these development projects, the community is largely focused on making a variety of standard external VCU and replacement control boards which will handle the ever growing list of OEM components.
Getting Started
Its recommend reading the Glossary of Terms before read further.
A few main parts are needed for a ev conversion, such as:
OEM Parts
A variety of OEM manufacture parts members of the community have reversed engineered for custom use cases:
FAQ
Open Inverter Related Projects / Control Boards
core universal hardware and software components
ZombieVerter VCU Tesla Small Drive and Large Drive Units:
commonly there is a large drive unit and small drive unit available.
These combine the inverter and motor into a single package. The
control boards for these replace the existing control board within them.
Open Inverter Hardware
Lexus GS450h Inverter / VCU:
the GS450h provides a gearbox (where the motors are located)
combined with the original inverter, this board looks to control
the inverter and the gearbox itself to provide a powerful set up
suitable for rear wheel drive set ups, replacing the existing
longitudinally mounted gearbox.
Prius Generation 3 Inverter:
a cheap available inverter from the popular Prius hybrid, this
Open Inverter Software
Auris/Yaris Inverter:
similar to the Prius board, there's subtle differences between them and
therefore the need for a separate board.
Nissan Leaf Gen2 Board
replaces the nissan OEM logic board with a rev 3 openiverter main board
Ford ranger ev board
openinverter kit for the ford ranger ev
CAN communication
The openinverter firmware uses a set of about 70 parameters to adapt it to different inverter power stages, motors and position feedback systems. Also it lets you calibrate the throttle pedal, change regenerative braking settings and so on. Working parameter sets can be found in the openinverter parameter database
Both the open inverter and some OEM inverters can be used as a battery charger, further saving on component costs. You can read more about how the open inverter and the theory of charging here
Open Inverter CAN std.
Legalities
Conversion Projects
