Locked
Has thanked: 11 times
Been thanked: 346 times
I have no way to know. Just taking it at face value. I do however feel I'm being backed into the refund corner yet again. If so then I'm out.
Has thanked: 403 times
Been thanked: 260 times
Post by MattsAwesomeStuff »
Jack Bauer wrote: Tue May 05, 2020 5:57 pmI do however feel I'm being backed into the refund corner yet again. If so then I'm out.
Why would someone think that you offer Spanish support on an English website?
Do they expect you to speak every language in the world at a technical level? What if they want you to communicate using only Peruvian Folk Dance?
I'd just straight up refuse a refund.
Have they even attempted to post here and ask their questions?
Tell them to use Google Translate and post in English here and translate back and read in Spanish.
PacEmaker
Has thanked: 5 times
Post by PacEmaker »
1000% agree with MattsAwsomeStuff. It's entirely on the customer. If he can read enough to buy the thing he can read enough to use the forum. Either that or he can sell it on the bay. You couldn't be clearer in your terms of sale Damien, so he has no legal leg to stand on and no ethical leg either. Sin piernas
Geoff
Is this smoke trying to tell me something ... :twisted:
jnsaff
Been thanked: 8 times
Post by jnsaff »
Jack Bauer wrote: Tue May 05, 2020 5:57 pm I have no way to know. Just taking it at face value. I do however feel I'm being backed into the refund corner yet again. If so then I'm out.
How you gonna survive in Lanzarotte without Spanish?
Ah s^&t! good point! Just when I'm about getting up the courage to test my dodgy German on Johannes :)
Filip
Post by Filip »
Recieved my VCU today (thanks Damien!), I have one question already, which enclosure should I buy? I tried a search but only came up with the section that´s already there, or maybe the VCU gets too hot inside those small enclosures and that´s why the part number isn't written with the Molex connectors on Github?
Enclosure part number is listed in the BOM :
https://github.com/damienmaguire/Lexus- ... V1_BOM.ods
Filip
Post by Filip »
Darn! Should have checked that list too... Thank you!
jcwright45
Post by jcwright45 »
xp677 wrote: Thu Feb 20, 2020 12:50 am It's glued/bonded in - I had to smash mine out. I think I used a screwdriver and then a craft knife to clean up the rest. Be careful not to cut yourself or scratch the aluminium, it's a mating face for my cover!
DC bus cover pictured in my last post is done. I just want to add o-ring grooves around the cable entries, and a million other tiny things that I'll notice.
Image Image
Now onto the converter input cover!
Amazing designs for the HV and input converter covers. Are they complete? Can the files be shared to print them out ourselves? Thanks
jcwright45
Dilbert wrote: Mon Mar 16, 2020 3:04 pm The thread on the GS450h gearbox connections has all the info you need. Auto-click in the UK has required connectors. You can also buy the other connector from them too.
viewtopic.php?f=14&t=271&start=10
Above you state Auto-click has all the necessary connectors. I have ordered everything but the main inverter connecto,Inverter interface connector (A62) 90980–12630. Unfortunately my inverter did not include the wiring loom. Now I understand that's a critical element but not before buying my first one. Does anyone have a source to buy or options for a work around?
Filip
Post by Filip »
This is my version of inverter connector, based on Molex parts.
First I tore the original connector apart
Then I soldered the wires to the new connector.
After that it was time to try to fit the new connector to the inverter, I used the old connector and cut it flush.
Then some cutting with the knife to get it square, and last but not least some sealant between the two.
This is the final inverter connector:
If anyone is interested I have all the partnumbers for my build somewhere, I can post them if there is interest.
jcwright45
Filip wrote: Sat May 09, 2020 11:56 am This is my version of inverter connector, based on Molex parts.
Molex part number please.. Thank you
Filip
Post by Filip »
Ok, here's the list!
36638-0002 CMC header connector 48pin 1pc
64320-1311 CMC receptacle 48pin 1pc
64320-1301 CMC wire cap 1pc
64323-1039 CP terminal 4pcs
64323-1029 CP terminal 32pcs
64325-1010 CMC plug 8pcs
64325-1023 CMC plug 4pcs
xp677
Been thanked: 15 times
Post by xp677 »
jcwright45 wrote: Sat May 09, 2020 10:50 am Amazing designs for the HV and input converter covers. Are they complete? Can the files be shared to print them out ourselves? Thanks
These are still not quite ready, I need to work on the seals between the sections and make some adjustments to the fit, especially on the converter piece, which needed notching on the prototypes to clear the water inlet casting.
jcwright45
Filip wrote: Sat May 09, 2020 5:36 pm Ok, here's the list!
Brilliant.... Thank you
RE3Rotor
Post by RE3Rotor »
Fits perfectly. Thanks Filip. If you don't mind, we should add this to the wiki.
Filip
Post by Filip »
Great to see! You´re welcome ;-)
I don´t mind at all, if I can contribute I'm just happy.
Robbertjanzen
Post by Robbertjanzen »
I have updated the drawing after some remarks and updates found in the software.
Hope this helps
GS450H Wiring overview V2.3.pdf
(1.31 MiB) Downloaded 490 times
jcwright45
Robbertjanzen wrote: Wed May 13, 2020 6:37 pm I have updated the drawing after some remarks and updates found in the software.
Hope this helps
Amazing, helps to see the whole picture. Thanks again.
Kevin Sharpe
Post by Kevin Sharpe »
Hope this helps
Very cool :)
The HV- contactor would normally use the key switch to ensure it's closed when ever the precharge or HV+contactors are closed.
I would also recommend adding an inertia switch in the 12V supply to the HV- contactor to cut power after a collision.
arturk
Has thanked: 7 times
Post by arturk »
Hope this helps
Attached is pinout for Generator Resolver connector (E81)
Bassmobile
GS450H Oil Pump Controller Part No. ?
Post by Bassmobile »
Anybody help a guy with the part number for this Oil Pump Controller?
Can somebody add this part No. to the Wiki possibly
arturk
Post by arturk »
Here it is
xp677
Post by xp677 »
Pretty sure the oil pump controller needs its own thread by now :D.
I for one welcome our new oil pump controller overlords.
Locked
