Chademo with Leaf PDM on Zombi VCU
Rustybkts
Has thanked: 17 times
Been thanked: 11 times
Post by Rustybkts »
Can the Zombi VCU control Chademo when the Leaf PDM is enabled which allows the use of the Leaf charger.
As soon as Chademo is selected on "Interface", the HV contactors close unless "Chargemodes" is selected to Ext_Digi.
Normally for Leaf PDM control it is set to Leaf_PDM.
I can use the Orion BMS for Chademo control but will need to trigger the HV contactors and assume that the HV request pin 51 is used to be triggered by the BMS.
Has thanked: 330 times
Been thanked: 848 times
Re: Chademo with Leaf PDM on Zombi VCU
I believe the Nissan PDM as the Chademo gateway is not implemented.
Gen 1 and 2 are in the PDM, Gen 3 is via the VCU.
Rustybkts
Post by Rustybkts »
I have HVreqFunc set to HVrequest but pin 51 doesn't work when connected to 12v high or ground.
Is this inhibited by any other input/setting and is high or low for on.
Okay pin function HVrequest is a dead end in code.
Use DCFCRequest with the Chademo DCFC set, it should enable properly on and off.
Rustybkts
Post by Rustybkts »
DCFCRequest not enabling HV contactors on pin 51 when set.
Tried using DCFCRequest on pin 50 GP12VINFunc but nothing.
I have never used it and have no experience with Chademo on the Zombie, so other will need to chime in.
Setting up my bench test zombie.
Interface: Chademo
Charger: None
Pin Function DCFCRequest on pin 51 Hvrequest
Toggle Charge Mode on and off.
Interface: Chademo
Charger: Leaf PDM
No need for input it goes to AC charging, not good. Will need to review, Chademo needs to be reviewed as the different charger interfaces work slight different.
Chademo is not correctly setup to allow chargers do its own thing right now as its a dedicated DC interfaces and needs another way to do the AC charging.
All this is on the list of things to overhaul and clean up.
Rustybkts
Post by Rustybkts »
Yes I found that selecting Chademo on Interface with Charger set to Leaf PDM brings in the HV immediately as Chademo requires Ext_Digi.
I am not using the Zombi VCU for Chademo so only require the HVRequest input to pull in the HV contactors. The Orion will do the rest with possibly more control than the Zombi VCU offers.
From my perspective, I only require the Leaf PDM AC charging to detect 16A as well as 32A plugs (0x390 byte_5 0x84 and 0x88), HVRequest to pull in the HV contactors and some way of reducing the power drain on the 12v battery supply to the Leaf inverter and PDM as it is almost an amp in total.
Would be happy to beta test any changes.
Rustybkts wrote: Wed Feb 12, 2025 1:45 pm Leaf PDM AC charging to detect 16A as well as 32A plugs (0x390 byte_5 0x84 and 0x88)
Where you find this info or share this testing?
Rustybkts wrote: Wed Feb 12, 2025 1:45 pm power drain on the 12v battery supply to the Leaf inverter and PDM
Sleep is coming with the updated Leaf CAN message generation.
Rustybkts wrote: Wed Feb 12, 2025 1:45 pm HVRequest input to pull in the HV contactors
Will look into this, needs working out properly and not just for your specific situation.
Rustybkts
Post by Rustybkts »
tom91 wrote: Wed Feb 12, 2025 3:41 pm Where you find this info or share this testing?
On an earlier thread last reply viewtopic.php?t=6027
I assume it will also rectify the requirement for a power reset of the VCU after each charge session viewtopic.php?t=6088
Understood but just needs to enable the HV contactor sequence when the Leaf PDM is selected and HVreqFunc is set to HVrequest and pin 51 enabled.
Can you measure the Proximity to ground resistance of the two plugs used to produce this please.
J0hannes
Has thanked: 21 times
Been thanked: 182 times
Post by J0hannes »
Nissan PDM related, do you have PDM pin 9 energized when trying to have DCFC contactors controlled?
It's and additional layer of safety Nissan has implemented
Also, I don't know if this has been noted earlier, but the PDM has a plug in signal for indicator lamp. Pin 10 is pulled down when PDM thinks it has a charging plug. I'll be using this for a dash light as it's in Leaf.
Rustybkts
Post by Rustybkts »
tom91 wrote: Wed Feb 12, 2025 4:52 pm Can you measure the Proximity to ground resistance of the two plugs used to produce this please.
The 32A EVSE lead is 222R and 16A lead is 680R
Rustybkts
Post by Rustybkts »
J0hannes wrote: Thu Feb 13, 2025 8:18 am Nissan PDM related, do you have PDM pin 9 energized when trying to have DCFC contactors controlled?
Will try the charge lamp signal from the PDM as the 106 Electrique dash has one.
My AC charger is working so not sure if I will need the PDM pin 9 utilised.
CHAdeMO will be controlled solely by the Orion as long as I can enable the HV contactor sequence.
GregFordyce
Has thanked: 43 times
Been thanked: 29 times
Post by GregFordyce »
I know this is an old thread but the topic is relevant to my situation. I'm trying to get Chademo working on my van. I'm using a full Leaf stack from a 30kWh AZE0. The wiring is shown below.
Wiring schematic
Wiring schematic
When I try and DCFC the station shows vehicle detected, communication established but fails on the final safety checks. My van goes into charging mode when I power pin 2 and earth pin 10 on the Chademo plug as well as when connecting to the charging station.
I'm not sure about some of my wiring, specifically Pin 2 Chademo -> pin 20 PDM?. Maybe it should be going to pin 22 PDM?
Also pin 7 Chademo currently isn't connected, but the diagram shows it connected to a 12v pullup resistor.
Should I connect it?
What value resistor should I use?
Should the 12v be constant or from the enable relay?
Once I get this working I'll add the info to the wiki.
My params file is below and I'm on 2.30.A
params (3).json
(2.14 KiB) Downloaded 9 times
Peugeot Expert LWB 2009
Zombieverter - Full Gen2 Leaf stack
24kWh & 30kWh Leaf batteries in custom battery box under van
GregFordyce
I looked again at how the Leaf PDM is wired to the Chademo socket and changed around PDM pins 20-22 as per this diagram.
Sadly still no charge. I suspect the quick charge contactors aren't closing. Can someone confirm this is how it should be wired and what is required to close the QC contactors in the PDM?
GregFordyce
I confirmed today that the quick charge contactors are not closing when I power pin 2 with 12 volts and earth pin 10.
What is required to close the contactors in the PDM? I suppose I could brute force it by wiring directly to the contactors but I'd rather not.
J0hannes
Post by J0hannes »
GregFordyce wrote: Mon Apr 27, 2026 10:41 am I confirmed today that the quick charge contactors are not closing when I power pin 2 with 12 volts and earth pin 10.
I'm actually starting to look at getting chademo working on my 2017 Leaf stack, so interested to hear if you find a working solution.
Has thanked: 246 times
Been thanked: 469 times
What year pdm?
If you can’t tiger the dcfc contactors externally then you’ll need to hardwire them unfortunately
GregFordyce
Bratitude wrote: Tue Apr 28, 2026 6:32 pm What year pdm?
My van has a 2017 AZE0 from a 30kWh Leaf and the pictures below are from a 2015 24kWh.
I've come to that conclusion as well. So in preparation I lifted the lid on my spare AZE0 leaf stack so I could get to the PCB on the QC/dcfc contactors.
QC pcb
QC pcb
I've done a partial schematic of the pcb.
  • CN701 pin 1 -> CN711 pin 2
  • CN701 pin 2 -> CN712 pin 2
  • CN701 pin 3 -> pins 1 on both CN711 & CN712
Schematic diagram
Schematic diagram
So it looks like the Leaf can control the contactors individually as we have 2 feeds and one common. That means this is useable as is and the only wiring modification needs to be done at the other end of the pdm. That will be tomorrow's job and then test Chademo.
Below is a front and rear picture of the pcb.
So a gen2 pdm I guess?
That board is the contractor economizer board so definitely don’t bypass it! Looks like you got it though
CHAdeMO is definitely a bit finicky with zombie, im having some issues with HVactive not being enabled. So more to follow suit
GregFordyce
Bratitude wrote: Tue Apr 28, 2026 10:34 pm So a gen2 pdm I guess?
Yes, gen2.
This is not an economizer board, the connections on pins 1-3 of CN701 pass straight through the board, it's simply acting as a junction block for the QC contactors, but you are right, it doesn't need bypassing. The rest of the circuitry on the board is an isolated signal back to the PDM, on pins 4-6, to indicate the contactors are closed and probably also to check for a welded contactor condition.
J0hannes
Post by J0hannes »
GregFordyce wrote: Wed Apr 29, 2026 7:56 am Yes, gen2.
Since you have the PDM hat open, would you check whether the pins 1-3 of CN701 are directly connected to PDM pins 21 & 22?
Or if not, how they are connected?
And what energizing PDM pin 9 actually does?
GregFordyce
Success, Chademo is working on my Gen 2 Leaf stack! 8-) Now for how we got there.
https://www.youtube.com/shorts/2yLIPDVTzH8
First step, follow Damien's video https://www.youtube.com/watch?v=zuPvgzQt6XQ and wire up your Chademo port as shown below.
Chademo wiring for Gen2 Leaf PDM
Next the cover is removed.
400 volts under this cover!!!
Follow all safety procedures as you will be working next to 400 volt exposed conductors. Disconnect all batteries and remove any service plugs.
With the cover removed check for continuity between Chademo pin 2 and pin 3 of CN701 (you will also have continuity to pins 1 and 2 through the contactor coils). Once this is confirmed okay, cut the cable tie (red arrow), remove the plastic cover and disconnect the 2 connectors (blue and green arrows).
Pin 6, pink wire to Chademo pin 10
Check for continuity on the pink wire, pin 6, to Chademo pin 10. If okay cut wire as shown. The black/yellow wire, pin 4, goes to Chademo pin 2. The plastic sleeving around the wire harness can be pushed back if it's to close to the connector.
Pins 3&4 to Contactors
Check for continuity from pins 1 and 2 of CN701 to pins 3 and 4. If okay, cut as shown. Join these 2 wires together and connect to the pink wire leaving a bit of slack so it can fit under the plastic cover. Reconnect both connectors and check resistance between Chademo pins 2 and 10. Expect to see around 10 to 12 ohms.
Next test the contactors close with 12v applied. (video below) NOTE, vehicle 12v and traction pack are NOT connected for this test!
https://www.youtube.com/shorts/EU6L3haZdI8
Watch out for 1 long screw!
Refit the plastic cover, the screw with the screwdriver sticking out of is longer than all the rest. I also fitted 2 white cable ties as shown.
PDM pin 9 seems to go to the lower section of the PDM. I'm not sure what it does but I have connected it as shown above.
I'll add this to the wiki in a week or so after any comments/suggestions.
Happy Chademoing!
Greg.
