Chademo with Leaf PDM on Zombi VCU
Can the Zombi VCU control Chademo when the Leaf PDM is enabled which allows the use of the Leaf charger.
As soon as Chademo is selected on "Interface", the HV contactors close unless "Chargemodes" is selected to Ext_Digi.
Normally for Leaf PDM control it is set to Leaf_PDM.
I can use the Orion BMS for Chademo control but will need to trigger the HV contactors and assume that the HV request pin 51 is used to be triggered by the BMS.
- Has thanked: 328 times
- Been thanked: 847 times
Re: Chademo with Leaf PDM on Zombi VCU
I believe the Nissan PDM as the Chademo gateway is not implemented.
Gen 1 and 2 are in the PDM, Gen 3 is via the VCU.
I have HVreqFunc set to HVrequest but pin 51 doesn't work when connected to 12v high or ground.
Is this inhibited by any other input/setting and is high or low for on.
Okay pin function HVrequest is a dead end in code.
Use DCFCRequest with the Chademo DCFC set, it should enable properly on and off.
DCFCRequest not enabling HV contactors on pin 51 when set.
Tried using DCFCRequest on pin 50 GP12VINFunc but nothing.
I have never used it and have no experience with Chademo on the Zombie, so other will need to chime in.
Setting up my bench test zombie.
Toggle Charge Mode on and off.
No need for input it goes to AC charging, not good. Will need to review, Chademo needs to be reviewed as the different charger interfaces work slight different.
Chademo is not correctly setup to allow chargers do its own thing right now as its a dedicated DC interfaces and needs another way to do the AC charging.
All this is on the list of things to overhaul and clean up.
Interface: Chademo
Charger: None
Pin Function DCFCRequest on pin 51 HvrequestCode: Select all
Interface: Chademo
Charger: Leaf PDM
Pin Function DCFCRequest on pin 51 HvrequestChademo is not correctly setup to allow chargers do its own thing right now as its a dedicated DC interfaces and needs another way to do the AC charging.
Yes I found that selecting Chademo on Interface with Charger set to Leaf PDM brings in the HV immediately as Chademo requires Ext_Digi.
I am not using the Zombi VCU for Chademo so only require the HVRequest input to pull in the HV contactors. The Orion will do the rest with possibly more control than the Zombi VCU offers.
From my perspective, I only require the Leaf PDM AC charging to detect 16A as well as 32A plugs (0x390 byte_5 0x84 and 0x88), HVRequest to pull in the HV contactors and some way of reducing the power drain on the 12v battery supply to the Leaf inverter and PDM as it is almost an amp in total.
Would be happy to beta test any changes.
Where you find this info or share this testing?
Sleep is coming with the updated Leaf CAN message generation.
Will look into this, needs working out properly and not just for your specific situation.
tom91 wrote: ↑Wed Feb 12, 2025 3:41 pm Where you find this info or share this testing?
On an earlier thread last reply viewtopic.php?t=6027
I assume it will also rectify the requirement for a power reset of the VCU after each charge session viewtopic.php?t=6088
Understood but just needs to enable the HV contactor sequence when the Leaf PDM is selected and HVreqFunc is set to HVrequest and pin 51 enabled.
Can you measure the Proximity to ground resistance of the two plugs used to produce this please.
- J0hannes
- Has thanked: 21 times
- Been thanked: 182 times
Nissan PDM related, do you have PDM pin 9 energized when trying to have DCFC contactors controlled?
It's and additional layer of safety Nissan has implemented Also, I don't know if this has been noted earlier, but the PDM has a plug in signal for indicator lamp. Pin 10 is pulled down when PDM thinks it has a charging plug. I'll be using this for a dash light as it's in Leaf.
Will try the charge lamp signal from the PDM as the 106 Electrique dash has one.J0hannes wrote: ↑Thu Feb 13, 2025 8:18 am Nissan PDM related, do you have PDM pin 9 energized when trying to have DCFC contactors controlled?
My AC charger is working so not sure if I will need the PDM pin 9 utilised.
CHAdeMO will be controlled solely by the Orion as long as I can enable the HV contactor sequence.
- GregFordyce
- Has thanked: 43 times
- Been thanked: 28 times
I know this is an old thread but the topic is relevant to my situation. I'm trying to get Chademo working on my van. I'm using a full Leaf stack from a 30kWh AZE0. The wiring is shown below.
When I try and DCFC the station shows vehicle detected, communication established but fails on the final safety checks. My van goes into charging mode when I power pin 2 and earth pin 10 on the Chademo plug as well as when connecting to the charging station.
I'm not sure about some of my wiring, specifically Pin 2 Chademo -> pin 20 PDM?. Maybe it should be going to pin 22 PDM?
Also pin 7 Chademo currently isn't connected, but the diagram shows it connected to a 12v pullup resistor.
Should I connect it?
What value resistor should I use?
Should the 12v be constant or from the enable relay?
Once I get this working I'll add the info to the wiki.
My params file is below and I'm on 2.30.A
- params (3).json
- (2.14 KiB) Downloaded 2 times
Peugeot Expert LWB 2009
Zombieverter - Full 80kW Leaf stack
24kWh & 30kWh Leaf batteries in custom battery box under van
- GregFordyce
I looked again at how the Leaf PDM is wired to the Chademo socket and changed around PDM pins 20-22 as per this diagram.
Sadly still no charge. I suspect the quick charge contactors aren't closing. Can someone confirm this is how it should be wired and what is required to close the QC contactors in the PDM?
- GregFordyce
I confirmed today that the quick charge contactors are not closing when I power pin 2 with 12 volts and earth pin 10.
What is required to close the contactors in the PDM? I suppose I could brute force it by wiring directly to the contactors but I'd rather not.
- J0hannes
I'm actually starting to look at getting chademo working on my 2017 Leaf stack, so interested to hear if you find a working solution.GregFordyce wrote: ↑Mon Apr 27, 2026 10:41 am I confirmed today that the quick charge contactors are not closing when I power pin 2 with 12 volts and earth pin 10.
- Bratitude
- Has thanked: 246 times
- Been thanked: 469 times
What year pdm?
If you can’t tiger the dcfc contactors externally then you’ll need to hardwire them unfortunately
- GregFordyce
My van has a 2017 AZE0 from a 30kWh Leaf and the pictures below are from a 2015 24kWh.
I've come to that conclusion as well. So in preparation I lifted the lid on my spare AZE0 leaf stack so I could get to the PCB on the QC/dcfc contactors. I've done a partial schematic of the pcb.If you can’t tiger the dcfc contactors externally then you’ll need to hardwire them unfortunately
- CN701 pin 1 -> CN711 pin 2
- CN701 pin 2 -> CN712 pin 2
- CN701 pin 3 -> pins 1 on both CN711 & CN712
Below is a front and rear picture of the pcb.
- Bratitude
So a gen2 pdm I guess?
That board is the contractor economizer board so definitely don’t bypass it! Looks like you got it though
CHAdeMO is definitely a bit finicky with zombie, im having some issues with HVactive not being enabled. So more to follow suit
