Simp BMS
Jiyar
Re: Simp BMS
Post by Jiyar »
mane2 wrote: Sun Mar 02, 2025 11:01 am If you clone the repo, open it with VS Code and have PlatformIO installed, it pulls the required libraries and compiles successfully without any modifications. Just tested.
Thank you for quick response, I'll do that
johnsongt350
Re: Simp BMS
Post by johnsongt350 »
ImageHi I am having an issue getting my car to charge. I'm using the simp bms v2 and a simp charge. I have an elkon 6.6 charger. I have the charger wired behind contactors.
Please see the current settings on the dashboard. Let me know if you see anything I'm missing.
Has thanked: 209 times
Been thanked: 572 times
Re: Simp BMS
? post some more info on you issue.
johnsongt350
Re: Simp BMS
When I plug In the EVSE it indicates ready on the EVSE. Nothing happens, no fan, no charge. I have 12volts at the simp charge, good ground. All connections are secure. I have the proper resister in place as well. I was wondering if any of my parameters need to be adjusted in the photos above
Re: Simp BMS
This is not the SimpBMS but Vero-BMS I believe reach out directly to them. https://veroelectric.com/product/vero-bms-v2
johnsongt350
Re: Simp BMS
Ok thanks
toshimin
Re: Simp BMS
Post by toshimin »
Hello ;)
Has anyone run simp bms on lilygo T-CAN485 ESP32 segregator RS-485 ?
https://pl.aliexpress.com/item/10050036 ... pt=glo2pol
Re: Simp BMS
E46Kim wrote: Sat Jun 14, 2025 9:39 pm I’m working on a BMW G30 Gear Selector integration project using Teensy 4.0.
Go post in a relevant topic and not randomly in other topics.
Has thanked: 82 times
Been thanked: 424 times
Re: Simp BMS
Post moved to a new topic
