Thank you for quick response, I'll do that
Simp BMS
Re: Simp BMS
Please see the current settings on the dashboard. Let me know if you see anything I'm missing.
- Has thanked: 217 times
- Been thanked: 609 times
Re: Simp BMS
When I plug In the EVSE it indicates ready on the EVSE. Nothing happens, no fan, no charge. I have 12volts at the simp charge, good ground. All connections are secure. I have the proper resister in place as well. I was wondering if any of my parameters need to be adjusted in the photos above
Re: Simp BMS
This is not the SimpBMS but Vero-BMS I believe reach out directly to them. https://veroelectric.com/product/vero-bms-v2
Re: Simp BMS
Hello
Has anyone run simp bms on lilygo T-CAN485 ESP32 segregator RS-485 ?
https://pl.aliexpress.com/item/10050036 ... pt=glo2pol
- Has thanked: 83 times
- Been thanked: 431 times
Re: Simp BMS
Post moved to a new topic
- Has thanked: 17 times
- Been thanked: 22 times
Re: Simp BMS
I have an Eltek valere charger "eltek PC" I have used it successfully before in normal operation (ev)
Is it possible to charge in ESS mode using the AC present pin?
I want to use it in parallel to an inverter to charge at a higher rate.
thankyou
thankyou
Re: Simp BMS
Using more then one type of charger is not supported.bigmotherwhale wrote: ↑Mon Jul 14, 2025 3:13 pm I want to use it in parallel to an inverter to charge at a higher rate.
Re: Simp BMS
what would be the issue? the inverter is not controlled by simpbms, the eltek pc will be the only charger the simpbms "sees"
thankyou
Re: Simp BMS
You did not specify that. Then yes you can just have the SimpBMS configured with Eltek charger in ESS mode it continuedly sends the messages for chargers.bigmotherwhale wrote: ↑Mon Jul 14, 2025 4:49 pm what would be the issue? the inverter is not controlled by simpbms, the eltek pc will be the only charger the simpbms "sees"
Re: Simp BMS
sorry
does it turn off and on using the AC present pin like in EV mode?
that would be easier than using a relay to control AC mains to the charger
thanks again.
thanks again.
Re: Simp BMS
bigmotherwhale wrote: ↑Mon Jul 14, 2025 4:58 pm does it turn off and on using the AC present pin like in EV mode?
Re: Simp BMS
I think the code may have changed which is why im confused, do i have to put the serial number in manually for eltekPC and then flash it?
There is no longer a message received in 0x350 that is entered into ChargerSerial that i can find in the code or am I mistaken?
Re: Simp BMS
OutlanderBMSv2.ino
#define EltekPC 7
requires a login on 0x351
byte ChargerSerial[6];
there is no longer any code to take the charger announce from the 0x350 and plug it into ChargerSerial
also can i add to the if statement of ESS mode to use the AC present to enable charging?
like this:
if (millis() - looptime1 > settings.chargerspd) {
looptime1 = millis();
if (settings.ESSmode == 1 && digitalRead(IN3) == HIGH ) {
chargercomms();
} else {
if (bmsstatus == Charge) {
chargercomms();
#define EltekPC 7
like this:
chargercomms();
} else {
chargercomms();
Re: Simp BMS
I found the part thats been removed in the old commits.
case 0x350:
for (byte i = 0; i < 5; i++) {
for (byte i = 0; i < 6; i++) {
ChargerSerial = inMsg.buf;
Its not in the latest version meaning "EltekPC" charger wont operate as it requires login.
case 0x350:
