Thank you for quick response, I'll do that
Simp BMS
johnsongt350
Re: Simp BMS
Please see the current settings on the dashboard. Let me know if you see anything I'm missing.
- Has thanked: 330 times
- Been thanked: 848 times
johnsongt350
Re: Simp BMS
When I plug In the EVSE it indicates ready on the EVSE. Nothing happens, no fan, no charge. I have 12volts at the simp charge, good ground. All connections are secure. I have the proper resister in place as well. I was wondering if any of my parameters need to be adjusted in the photos above
Re: Simp BMS
This is not the SimpBMS but Vero-BMS I believe reach out directly to them. https://veroelectric.com/product/vero-bms-v2
johnsongt350
Re: Simp BMS
Hello
Has anyone run simp bms on lilygo T-CAN485 ESP32 segregator RS-485 ?
https://pl.aliexpress.com/item/10050036 ... pt=glo2pol
- Has thanked: 91 times
- Been thanked: 517 times
Re: Simp BMS
Post moved to a new topic
bigmotherwhale
- Has thanked: 17 times
- Been thanked: 25 times
Re: Simp BMS
I have an Eltek valere charger "eltek PC" I have used it successfully before in normal operation (ev)
Is it possible to charge in ESS mode using the AC present pin?
I want to use it in parallel to an inverter to charge at a higher rate.
thankyou
thankyou
Re: Simp BMS
Using more then one type of charger is not supported.bigmotherwhale wrote: ↑Mon Jul 14, 2025 3:13 pm I want to use it in parallel to an inverter to charge at a higher rate.
bigmotherwhale
Re: Simp BMS
what would be the issue? the inverter is not controlled by simpbms, the eltek pc will be the only charger the simpbms "sees"
thankyou
Re: Simp BMS
You did not specify that. Then yes you can just have the SimpBMS configured with Eltek charger in ESS mode it continuedly sends the messages for chargers.bigmotherwhale wrote: ↑Mon Jul 14, 2025 4:49 pm what would be the issue? the inverter is not controlled by simpbms, the eltek pc will be the only charger the simpbms "sees"
bigmotherwhale
Re: Simp BMS
sorry
does it turn off and on using the AC present pin like in EV mode?
that would be easier than using a relay to control AC mains to the charger
thanks again.
thanks again.
Re: Simp BMS
bigmotherwhale wrote: ↑Mon Jul 14, 2025 4:58 pm does it turn off and on using the AC present pin like in EV mode?
bigmotherwhale
Re: Simp BMS
I think the code may have changed which is why im confused, do i have to put the serial number in manually for eltekPC and then flash it?
There is no longer a message received in 0x350 that is entered into ChargerSerial that i can find in the code or am I mistaken?
bigmotherwhale
Re: Simp BMS
OutlanderBMSv2.ino
#define EltekPC 7
requires a login on 0x351
byte ChargerSerial[6];
there is no longer any code to take the charger announce from the 0x350 and plug it into ChargerSerial
also can i add to the if statement of ESS mode to use the AC present to enable charging?
like this:
if (millis() - looptime1 > settings.chargerspd) {
looptime1 = millis();
if (settings.ESSmode == 1 && digitalRead(IN3) == HIGH ) {
chargercomms();
} else {
if (bmsstatus == Charge) {
chargercomms();
#define EltekPC 7
like this:
chargercomms();
} else {
chargercomms();
bigmotherwhale
Re: Simp BMS
I found the part thats been removed in the old commits.
case 0x350:
for (byte i = 0; i < 5; i++) {
for (byte i = 0; i < 6; i++) {
ChargerSerial = inMsg.buf;
Its not in the latest version meaning "EltekPC" charger wont operate as it requires login.
case 0x350:
Re: Simp BMS
No.Also this BMS is legacy now for 3 years as the main processor is no longer made.
There is a user manual for it with all the info, check the first post.
marucha79
- Has thanked: 2 times
- Been thanked: 9 times
Re: Simp BMS
I modified the simpBMS code for Teensy 4.0 (Triple Can), and when connected to the Outlander battery, I'm getting strange module count readings. Is the problem with the BMU, or are the parameters in the code set incorrectly? I don't see something like the "number of modules" parameter, so I assume it's being read from CAN frames. There are 10 modules in OEM configuration.
Modules: 12 Cells: 80 Strings: 1 Voltage: 323.634V Avg Cell Voltage: nanV Low Cell Voltage: 4.029V High Cell Voltage: 4.062V Delta Voltage: 33mV Avg Temp: 15.031C
Module #1 32.35V Cell0: 4.05V Cell1: 4.05V Cell2: 4.05V Cell3: 4.05V Cell4: 4.04V Cell5: 4.04V Cell6: 4.04V Cell7: 4.04V
Temp 1: 17.89C Temp 2: 17.89C Temp 3: 18.52C
Module #2 32.45V Cell8: 4.05V Cell9: 4.06V Cell10: 4.06V Cell11: 4.05V Cell12: 4.05V Cell13: 4.06V Cell14: 4.06V Cell15: 4.06V
Temp 1: 17.89C Temp 2: 16.92C Temp 3: 18.52C
Module #3 32.35V Cell16: 4.04V Cell17: 4.04V Cell18: 4.04V Cell19: 4.04V Cell20: 4.04V Cell21: 4.05V Cell22: 4.05V Cell23: 4.05V
Module #4 32.31V Cell24: 4.04V Cell25: 4.04V Cell26: 4.04V Cell27: 4.04V Cell28: 4.04V Cell29: 4.04V Cell30: 4.04V Cell31: 4.03V
Module #5 32.39V Cell32: 4.04V Cell33: 4.05V Cell34: 4.05V Cell35: 4.05V Cell36: 4.05V Cell37: 4.05V Cell38: 4.05V Cell39: 4.05V
Module #6 0.00V Cell40: 0.00V Cell41: 0.00V Cell42: 0.00V Cell43: 0.00V Cell44: 0.00V Cell45: 0.00V Cell46: 0.00V Cell47: 0.00V
Temp 1: 0.00C Temp 2: 0.00C Temp 3: 0.00C
Module #7 32.31V Cell48: 4.03V Cell49: 4.04V Cell50: 4.04V Cell51: 4.04V Cell52: 4.04V Cell53: 4.04V Cell54: 4.04V Cell55: 4.04V
Module #8 32.32V Cell56: 4.03V Cell57: 4.04V Cell58: 4.04V Cell59: 4.04V Cell60: 4.04V Cell61: 4.04V Cell62: 4.04V Cell63: 4.04V
Module #9 32.31V Cell64: 4.03V Cell65: 4.04V Cell66: 4.04V Cell67: 4.04V Cell68: 4.04V Cell69: 4.04V Cell70: 4.04V Cell71: 4.04V
Module #10 32.46V Cell72: 4.06V Cell73: 4.06V Cell74: 4.06V Cell75: 4.06V Cell76: 4.05V Cell77: 4.06V Cell78: 4.06V Cell79: 4.05V
Module #11 32.39V Cell80: 4.04V Cell81: 4.04V Cell82: 4.04V Cell83: 4.04V Cell84: 4.05V Cell85: 4.05V Cell86: 4.06V Cell87: 4.06V
Module #13 0.00V Cell88: 0.00V Cell89: 0.00V Cell90: 0.00V Cell91: 0.00V Cell92: 0.00V Cell93: 0.00V Cell94: 0.00V Cell95: 0.00V
CANbus -0.09mA 0% SOC -109480.00mAh
Charger Status: 0 Charger Temp: 0 Charger Temp 2: 0 DC volts: 0.00
!!! Series Cells Fault !!!
Re: Simp BMS
Who knows what you have done to the code so cannot comment.
Hints are it is ready some messages as modules but shows 0V for all cells, so there can be additional messages that fall into the Outlander CAN frame formats.
